Is joule thief circuit gets overunity?
Started by Neo-X, September 05, 2012, 12:17:13 PM
ltseung888
Third and the last triple test on Board 39 for Energetic Forum.  In this test, a new AA battery was used.
The COP was -2.21.  The negative sign came from INPUT implying a feedback circuit.
This package is ready to be shipped.  I shall wait for comments from the Energetic Forum Administer and ship it out with the other Forum Boards.  This is the last chance for you all to recommend additional tests before shipment.  I included the .xls file to make sure all information is complete.
ltseung888
Third and last of the triple check on Board 38 for overunity.com.  The new AA battery used on Board 39 was again used.
For this board, the COP was -2.72.  The negative sign came from INPUT implying a Feedback circuit.
Ready to ship...
ltseung888
Here is the third test for Board 33 targeted for overunityresearch.com.
The COP was -2.83 using new AA battery as Input Source.
Your comments and suggestions on additional tests on the above three boards are welcome.  Once they are shipped out, the opportunity will be gone.
conradelektro
@Itseung888:
Please set your scope to 50µS (instead of 250µS) time base (the distance between vertical dotted lines on the screen).
Your scope is perfect, just change the time base setting from 250µS to 50µS, then one sees only three spikes on the screen (instead of 15 spikes) and the wave forms will be much better to see.
You do not need a "better oscilloscope", you just have to adjust the settings of your scope.
You have set the "time base control" (the scale of the time axis) of your scope to 250µS per division (distance between vertical dotted lines on your screen), therefore you see 15 spikes on the screen. 15 spikes are too many to see any details, the spikes appear small.
You should set the "time base control" (the scale of the time axis) of your scope to 50µS in order to see fewer spikes on the screen. Once you see fewer spikes the spikes will be enlarged and better visible. With a time base of 50µS you will only see 3 spikes and the spikes will appear bigger and clearer.
Greetings, Conrad
ltseung888
Quote from: conradelektro on February 24, 2013, 05:52:24 AM
@Itseung888:
Greetings, Conrad
@Conrad,
Here are the results you asked:  COP = -2.93 on Board 33 for overunityresearch.com using a New AA battery.
