Is joule thief circuit gets overunity?
Started by Neo-X, September 05, 2012, 12:17:13 PM
picowatt
TK,
Before you make too many changes, consider trying to duplicate the waveforms of your reply #522.
PW
Quote from: picowatt on April 10, 2013, 10:39:07 PM
TK,
PW
Yes, I have tried, both with the original transistor and the new one, using the same battery too, and I can't seem to do it. The traces always stay below the zero line. I am starting to wonder if I inadvertently set that channel to AC-coupled for that trace. It is barely possible that I flipped the channel coupling switch the wrong way after checking the baseline at "ground" coupling. I am having a hard time believing I would do that, though, since I did check the trace several times.
Awww... does that mean my little PCB JT isn't OU after all? I'm crushed.
picowatt
Quote from: TinselKoala on April 11, 2013, 11:09:21 AM
TK,
That would be my guess.  Its one of the hazards of doing late night 'scoposcopy...
PW
Well, the first place I generally try to look, to explain any anomalous results, is for my own errors. Thanks for suggesting that I try to reproduce that trace. I'm still not convinced that I actually did that silly mistake, though, so I am going to keep on trying. My own preferred suspect is a DC balance/offset error in the scope's internal calibration. Still, if that were the explanation I should have been able to reproduce the trace.
It's a good thing that Lawrence's scope shows the channel coupling right on the screen; sometimes he has used AC coupling deliberately, but at least he won't be using it accidentally without any way to tell, like on my scope.
ltseung888
Quote from: TinselKoala on April 11, 2013, 12:20:09 PM
I value my Atten Scope more now.  Just repeated the Input Waveform capture on Board 80.  You can draw the zero axis yourself.  It definitely shows current crossing the axis.....
