Thanks to ALL for your help!!
FREE Heat FROM spinning mangets
Started by gadgetmall, September 08, 2012, 10:41:22 PM
Doug1
 It could be useful if it was powered by a water wheel tied to a steam engine turning a gen. Steam engines are more efficient then IC's. There a ton of water wheel concepts. I like the double spoon rotor it uses less water volume. It can also second as type of steam turbo using steam preasure. Then you would get torq from the falling water and the steam combined.
Doug1
http://en.wikipedia.org/wiki/Pelton_wheel
  Here is an explaination of double spoon thingy. Combined with a steam jet in the water stream to move the wheel faster or stronger with even less water consumed. Run the magnets around the flat side of the wheel and a copper pipe past the magnets run to a third jet nozzle to aid in tunning of the wheel.
gadgetmall
That would be free Doug1 . the idea of induction heating from say an induction uses electric inductor coil and i just wanted to show that you can do the same thing with magnets on a wheel with Copper . I found it very interesting and you could put this on a water wheel like you said or even a stationary exercise bike with a flywheel . This would be a way to make heat in case we every have a holycaust and survival of the ones who have the knowledge can use this .
Statements like it's not free don't matter it is the point that it can be done this way . The point being is you really apply what you know for survival . gear up a 10 speed bike and power it with the Wind ..water ... etc...
Gadget
Ghost
use a stirling engine with this principle!
then loop the thing to heat itself.
:D
Low-Q
Quote from: Ghost on September 18, 2012, 10:35:09 AM
:D
Good idea, hehe :-)
