Free energy generating coil.
Started by synchro1, September 10, 2012, 10:32:48 AM
synchro1
Overunity currently features a front page video of a thick copper wire coil with a thick center tap spiral copper wire leading nowhere, and a horseshoe VCR magnet glued to the bottem. The video shows the coil and magnet generating 5.92 volts, and running a 9 volt D.C. motor.
I found measured voltage in a bifilar coil with a diametric tube magnet placed in the air core. This effect was tested and reported by me on the forums and adds legitimacy to this incredible video, which seemingly defys logic. This looks simple enough to replicate. I believe it's worth a try.
leonirz
For me, it is obviously a wireless energy transfer, where the other coil (energy emitter) is hidden of camera lens.
e2matrix
Quote from: synchro1 on September 10, 2012, 10:32:48 AM
This is quite different from what you describe however.  I don't see any reason to think this is real based on your experiment.  What voltage and current did you see on your setup?  Enough to run a small DC motor?   I really doubt it.  I can see voltage across any small piece of wire with a good meter or O-scope as long as just one lead is connected.  I hate to admit I even tried this but it was way to simple for me and I found the wire size he used stated somewhere and already had a piece just the right length in that exact gauge.  Took about 5 minutes including hot gluing a hard drive magnet to it.  Even used the same exact size alligator clips.  Nada.  Nothing.  No voltage and no current.  O-scope saw a little but only if I had one lead connected.  Connect to both ends and it drops to nothing.  I can read more voltage on that o-scope from my finger or a straight piece of wire the same length.  It's just picking up stray EMF.
This whole thing is as fake as it gets.  Just a creative magician.
gadgetmall
Quote from: leonirz on September 10, 2012, 11:11:07 AM
@synchro it's Busted ..By Tk ...your  beating a dead Horse ! The Guy is a TrIxTEr .already Dissussed and it is a FAKE GUYS .here you go read on and see http://www.overunity.com/12670/solid-state-free-energy-device-rebuilt-it-but-unsuccessful/
and if you want to cut to the chase Tk's magic coil http://www.youtube.com/watch?v=koNnPYjeKDE
gadget
The motor has a couple of button cells concealed inside it. The coil assembly is just a short, a jumper, nothing more. It makes the circuit connection inside the motor for its concealed button cells. Note how weakly his motor runs towards the end of the demo... the little batteries are going flat.
The meter is also "fekked" (a magician's term). As shown below. Again, the coil just acts as a jumper, to make the connection externally so that the meter measures the voltage of the concealed batteries.  Just make sure you leave the meter in the right range when you are doing this trick. You could even fekk the 9v battery, so that it would read the 6 v from the meter's internal battery plus the 3 volts you have hidden in the 9v case, to give a reading of 9v when you pretend to measure its voltage. This would also help the effect when you show the motor connected to the 9v..... you'd have its hidden 3v in series with the motor's hidden cells.
