Free energy generating coil.
Started by synchro1, September 10, 2012, 10:32:48 AM
synchro1
Quote from: gadgetmall on September 16, 2012, 01:55:37 PM
It Appears that someone is selling Ant and ground free energy coil on ebay . http://www.ebay.com/itm/Real-Free-Energy-Generator-Device-Electric-power-from-the-air-WORKING-UNIT-/261099190794?pt=LH_DefaultDomain_0&hash=item3ccab97a0a
             The output of this unit is directly proportional to the size of the antenna. Attached to an aluminium street lamp pole, it could generate enough power from ground to illuminate the overhead lamp.
kooler
DreamThinkBuild
Hi Syncrho,
Thanks for the Leon paper.
Would this work with a smaller coil inside a larger coil?
Step 1: Build up field of internal smaller coil.
Step 2: Build up inverse field in outer coil to compress the inner coils field.
Step 3: Quickly quench outer coil to load.
Step 4: Rapidly expanding inner field cuts outer coil which runs through load.
Loop back to Step 2
synchro1
@DreamThinkBuild,
            I wondered about that myself because the cost of the neodydmiums is so great now. I'm certain it would generate power, but it would most likely be<OU. Floyd Sweet's Vacuum Triode Amplifier or VTA, named by Colonel Bearden has the same three components, a coil sandwiched between two block magnets. Floyd used a Hi-Voltage coil to pulse and recover output and claimed 10's of Mega range OU factor. Floyd conditioned his own magnets by charging ceramic metals with wall current. Without the magnets, I think you'd just be treading water.
             My Dragone Magnet Pump in the video is technically a Floyd Sweet VTA without the PWM circuit due to the use of the Hi-Voltage coil.
synchro1
@DreamThinkBuild,,
JL Naudin's 2Sgen is a Magnet Pump too! JLN'S Magnet Pump works the same way as Dr. Dragone's and Floyd Sweets VTA. This variation's 8x overunity. The high permeability of the metglass toroid allows for higher pulse frequency. The toroid's magnatized by the tiny disk neo. The charge appears in the coil when the toroid field remanifests in the copper wire after coil compression's released after collapse.
High permeability diamagnetic semiconductor toroid cores can easily be cold molded by mixing pyrite (Fools Gold) with a good bonding agent.
