Free energy generating coil.
Started by synchro1, September 10, 2012, 10:32:48 AM
e2matrix
Quote from: gadgetmall on September 16, 2012, 01:55:37 PM
It Appears that someone is selling Ant and ground free energy coil on ebay . http://www.ebay.com/itm/Real-Free-Energy-Generator-Device-Electric-power-from-the-air-WORKING-UNIT-/261099190794?pt=LH_DefaultDomain_0&hash=item3ccab97a0a
Claims to charge a cell phone
possibly Tesla ? Like in this diagram
Thanks gadgetmall for the diagram.  I think that is correct for the Cook configuration although a bifilar, tri or quadfilar from what I've found seems to always connect a pair of wires from opposite ends together.  BTW that diagram with the dual Avramenko setup you posted like below is one I decided to try today.  It slowly built up to over 2.5 volts in about 20 minutes once I switched to some glass diodes.  I started with Schottky's but they were barely getting 1 millivolt.  I think the glass diodes were germanium but not 1n34's.
I also finally graduated from Joule Thief school  - LOL  - I dont' think I ever had built one that worked but got one to work easily today.  I think my attempt last night was with a bad transistor.  I was trying to get one also built per Groundloops extra low current version to try running that off the dual Avramenko power (thus no battery at all) but GL's setup didn't work at all for me.  The regular JT would light off the dual AV plug just for a blink but that was all.  I didn't really have an Antenna setup either - just a wire hanging out a 2nd story window.  It did seem to help a bit when I ran it through that big coil of intercom wire though.
synchro1
Quote from: e2matrix on September 16, 2012, 10:37:44 PM
@ematrix2,
                 I think it would help if the intercom wire antenna were wired like you're "wrong way to wire quadfilar". Also, it would help to unwind it and cover an east west wall, running the wire back and forth.
synchro1
             Dragone shows an axial polarized magnet next to a standard coil that equals the magnet in electromagnetic strength. The coil's magnetic strength is a function of wire thickness, number of turns, and power supplied. That's described in his equation of Ampere's law. The upshot is when the permanent magnet and the coil pick up the same number of iron tacks, the permanent magnet has a power equal to 1a. This is the power it takes to suppress and neutralize the field of the permanent magnet.
             The Bi-Filar hi-voltage Tesla wrap has a c factor of 250,000 times the power of a standard coil. This is the type of wrap JLN uses to cover his metglass toroid with. One can see at a glance where the overunity factor comes from. The Neo Disks in my Dragone Pump are millions of times the strength of JLN'S toroid. These magnets do work on the bifilar coil and absorb ambient room heat to restructure the Quantum Layer disturbed by the coil torque. This heat exchange generates the electrical output, and takes place on the atomic level.
gadgetmall
@E2matrix Hey Congrats on Jt school  . the main problem every one has was connecting the oppisite ends together . then if it didn't light you switch the wires on the base and emitter . getting that in phase is the main thing on any Jt . I have adiagram to make a jt run on just 2 micro amps at 0.3 volts if intrested ,...
Glad it's working for you . Yes i tried the Bifiallar setup and it didn't work for me either . The way i drew it is exactly the way it is in the cook battery diagram . we use one wire off each set of coils ..
Doug1
Drogone's paper looks like a variant of Teslas work on pat 413353. Telsa has one version using perminent magnets but his dicriptions are more vague.
  The cylinder with the winding can be found in electric wheel chairs. On the end of the motor is a breaking unit built exactly as drawn in Drogone's drwingings. Just in case anyone wanted to go an easier route with off the shelf parts. You just need a magnet to fit inside the center hollow tube.
