Free energy generating coil.
Started by synchro1, September 10, 2012, 10:32:48 AM
synchro1
Dr. Kanzius burned saltwater by broadcasting RF signals at 13.56 Mhz. Dr Stiffler illuminates a large rack of LED's by capturing RF power on the same bandwidth of 13.56 Mhz. He substitutes the capacitive resistance of two aluminum blocks for the ground, and captures the background excitement of the Hydrogen Molecule, perhaps generated by the pounding Ocean surf on the shore line! This thought occured to me as an explanation for the power I generate with my four wire intercom coil which I tested on the North Coast of California, in close adjacency to the Ocean Surf!
synchro1
I think I might be on to something here by way of theoretical explanation. Here's a video of Lidmotors Loop antenna. It's a coil of Litz in series with a capacitor. Dr. Stiffler uses this kind of loop antenna to recieve his power signal at 13.56 Mhz. This is practically identical to the intercom coil, two loops attached in series to a capacitor through a glass diode. Take a look at this to start:
http://www.youtube.com/watch?v=XrQH1ww6q7s
Stiffler posted a video where he lights an LED with three free energy coils, a capacitor and diode. The Intercom Coil has four.
"In the Stiffler system, Dr. Stiffler uses only a capacitor, a diode, and three coils in resonance."
"In a replicated system posted by K4ZEP, only three coils are used. The output is obvious as the LED lights up. K4ZEP claims that it will also work with radio frequencies as the input."
K4zep states the three coil resonating circuit is running at 14.9 Mhz. This is pretty close to the 13.56 of Kanzius and Stiffler:
My base frequency is 14.9 megahertz but I am also getting a big spike down below almost the bottom of the pass band of this device. and it is just all over the place it has become very much more active I just discovered my RF meter here laying on the table top is showing 35 mv of RF down here, from up here, down here. And as you can see I am running 14.903 megahertz wrf 6.6 resistance of 31 ohms and an impedance of 75 or 76 ohms.
For some unknown reason, K4zep has taken down his videos.
