Free Electric Multi-use motor - Home gen-Car motor-Boat Motor-lawn mower
Started by inventacom, September 15, 2012, 11:13:45 AM
gadgetmall
that would be great Brad . I don't have a  clue as to even start  looking for the patent without a named device .
I really would like to see that.  Also that BIG 45kw generator video  looks feasible to run it self and would be a worthy project if one had the money and or resource .  . A twist of the shaft runs a side grinder. 750 rpm puts out 45KW . wow these are real and for sale  . example here's one 1300KW @ 750 rpm . Cost a fortune .4094363.0000 US dollars http://www.ebay.pl/itm/Wind-Water-Magnet-Generator-1300kw-1-3MW-750rpm-/280966169403?pt=LH_DefaultDomain_212&hash=item416ae3833b
As we see there is no free energy there :) But hey if your a billion air it's pocket change to have your very own self running power station.
Something that big could kill you with the juice it produced with one twist on the shaft.
thanks Brad  .
b_rads
Quote from: gadgetmall on September 21, 2012, 10:05:35 AM
Here you go -
This is also featured in Patrick J. Kelly "Practical Guide to Free-Energy Devices"  Chapter 2
Brad S
Vortex1
Oh Yes, the Jim Hardy waterwheel....whatever happened with that? no replicators? 2007 patent app still not granted, AFAIK. (as far as I know) no pun intended.
Regarding the use of flywheels....they only add instantaneous peak power reserve to a system, and act like supercapacitors that supplement batteries in an electric dragster.
All of the systems I have seen using flywheels and lots of belts and pulleys only seem to obscure the truth.
If a flywheel gave you something for free, you could just run one directly from the shaft a PM DC motor (which is also a generator) and eliminate all the obfuscation.
Torque converters and transmissions are the equivalent analog to electrical transformers,
torque vs. speed........current vs voltage. No power gains in these. Yet.....
Still we hope and do research.
e2matrix
From what I have picked up Inventacom does have a job and if he is stilll doing handyman work as he mentioned he may be busy between that and getting the info to his computer I'm still going to assume it's just life as usual - things always taking longer to get done than one expects.  For us on the waiting side it seems like forever.  But I would expect to hear from him by Saturday or Sunday at the latest.  If not then we may consider whether we want to think we've been scammed or whether the MIB's got him ;)
It does seem there have been more motor related inventors get trouble in some way or another than other types of inventions.
As far as how I think this may work here are some thoughts.  There are several devices including the blind Peruvian inventor whose device has gotten a lot of attention.  A very good engineer on energeticforum has thoroughly analyzed how this unit is getting extra energy.  Some of the sharpest people over there are looking at it and seem to be in agreement that indeed it can get extra energy coming into the system.  I believe (I haven't studied the message thread well) that it is a combination of well timed gravity and inertial forces.  We've seen this before in some other systems which use fairly large or heavy flywheels.   I even suspect that may be why those were not shown in the pictures we have so far as that may be where the magic is at and maybe inventacom was still not certain how far he wanted to go with this (all speculation I know but that's all I've got at the moment).   The Chas Campbell setup also comes to mind as seen in Patrick Kelly's free energy book.  While he seems sincere in claiming it is free energy and I think it may be I don't know of anyone who has replicated it.  It would involve quite a bit of precision building and some detailed specs.  I don't believe there is a lot of details available so it may be another one of those potential units that is real but just a bit more than most people want to get into.
In looking at Inventacoms bracket that holds the Fan motor I found it surprisingly thick.  It looks like 1/4" or 5/16" thick steel for a fairly small motor.  Why would he use something that thick?   I think it is possible there may be a pulley that is off balance or something that is not a standard symmetrical pulley which may need the extra strength of that really thick bracket to keep things stable.  Any way that's just my guesses at this point.
vince
Hi Guys;
I was really skeptical about that little 12 volt blower motor being able to turn that generator so I did a little testing.
I have a Nissan Micra blower motor which is 12 volts and 160 watts according to the nameplate. I know inventacom has a bigger motor but I still think this should give a close representation.
I hooked it up to 3 different loads to see if it could cut it.
Here's my results.
!/2 hp induction motor 120 volts, about 1 to 1 ratio, using dishwasher belt.
Motor would get to 1700 rpm and with capacitors I was able to get about 4 volts ac
Blower motor gets hot.
2 HP, 220volt Baldor motor, about 1 to 2  ratio, using dishwasher belt.
Motor could not get above 100 rpm and with capacitors would not produce power because it was no where near required speed
Blower motor gets really hot and struggles
2HP @120  DC PM motor, 14 amps @ 6000 rpm,approx 1 to 1 ratio  using dishwasher belt.
Motor would easily spin over 4000 rpm and produced about 36 volts DC
In all cases the blower motor was powered by a battery charger set on 60 amp 12volt boost circuit. It almost always drew about 40 amps.
I just can't see that little motor turning that generator to the right rpm as it looks.
Vince
