Free Electric Multi-use motor - Home gen-Car motor-Boat Motor-lawn mower
Started by inventacom, September 15, 2012, 11:13:45 AM
FatBird
Vince, I think you are right on your theory of Load RPM vs No Load RPM.  Thank you for sharing that.
DreamThinkBuild
Hi FatBird,
I had the same problem so I downloaded and installed Total Commander.  The files opened with no problem in Total Commander.
Total Commander website
http://www.ghisler.com/
gadgetmall
e2matrix
vince,  Thanks for running those tests.  I wouldn't have thought of that being reduced that much under the fan blade load but that's a very good point.  I'm sure that is a good assumption that the motor be run somewhere in it's normal load range.  It can probably be plus or minus maybe 20 or 30% or so and still work but it's a point to consider for optimization.
e2matrix
@ALL - I did send out a second email.  That email contains new different links for the file which should be fixed so that it can be unzipped by WinRAR (which is what I used this time) or WinZip or 7Zip.  So if you are having trouble make sure you have the new email with the new links and try either of those 2 file servers to re-download the file.   It has now been tested with WinRAR, WinZip and 7Zip.  It works fine with all three archivers, unarchivers.
