Free Electric Multi-use motor - Home gen-Car motor-Boat Motor-lawn mower
Started by inventacom, September 15, 2012, 11:13:45 AM
badlogik
Hi all-
Just going to post my skillset as requested:
PC Geek (Support Analyst by trade)
Backyard Mechanic
Magnet Fanatic
pretty bright guy
good with tools
dad
e2matrix
Quote from: FatBird on September 24, 2012, 09:11:44 AM
Click on the Link below to read about the Kipper Motor Generator that was SELF RUNNING.
==>   One IMPORTANT THING is that it took PATIENCE & TIME for it to start running overunity!!!!
http://www.teslatech.info/tttechspec/energy/kipperplan.pdf
If you look close, you can see his motor & generator sitting vertically in a box with their pulleys pointing up.
IMPORTANT:  Please re-read what is said in the PDF File about the WIRE LOOPS being the most important part of it.
                     Is it possible the Loops of Wire enabled it to tap into Zero Point Energy???
==>  Page 4 of the PDF, 2nd paragraph from the end, the greater the Load, the FASTER IT TURNED!!!!
Hi Fatbird,  I had looked into that Kipper motor a while back and found enough evidence by others to consider it a fake.  He apparently was transmitting power to it from nearby - in one case from his truck when they did a test out in the desert or away from any civilization.   I also met and know Steve Elswick (the magazine owner that article was in) and consider him just an opportunist making money of promoting anything that looks like free energy - no matter if it's real or not.   Elswick has in some ways done some good things promoting FE but I don't believe he has an interest in whether something is real or not.
e2matrix
Quote from: FatBird on September 24, 2012, 12:44:46 PM
@ Skywatcher,   That download site wants to download a dangerous executable file before it will download your PDF.
                          Please post that PDF file right here on this thread, just as if it is a picture.  Thank you for sharing sir.
@ Vince,  Thank you for sharing your setup pictures.  Another thing you might want to try is to couple the shafts of 2 identical Radiator
                Fan Motors, using a piece of hose, shaft to shaft.  One would be the drive motor, & the other the Gen.  The output will be
                DC, but there is nothing wrong with DC.  A cheap 12V to 120V Inverter can produce the AC, if & when needed.  LOL
                Vince, the reason your picture above isn't showing up is because it's over 600 pixels.
Actually that page is typical of a lot of download sites.  They put up several download buttons and many of them try to get you to download an executable which may be dangerous and at best worthless.  They are usually the bigger more obvious download buttons.
    But his file IS THERE in the smaller blue centered link to be downloaded without any executables.
gadgetmall
Vince No it is Very Interesting information and not boring at all .
Thanks fatBird !
Goat . I have Seen Stranger Things .
Thanks for the head up E2matrix . wa just getting ready to hit one of those buttons !
It is the one that says Click here to start download from sendspace
vince
@ Gyulasun,
So Sorry Gyula
For some reason I had Gotluc in my memory and mixed you two up. I Apologize!
It was indeed you that gave me the info.
Thanks
Vince
