0 Members and 357 Guests are viewing this topic.
27Bubba
For those of you who like to read about it from the beginning please refer to page# 925, post #13872 ;D
Zeitmaschine
First of all the name is dally, secondly he has dismantled his device, so there is a good chance it will never work again, thirdly the whole presentation is suspicious anyway and fourthly he could be a cousin of Kapanadze indeed. :D
T-1000
 Hello,
Since there was wish to separate Dally device thread, here are my posts and translation from Russian to English:
solid state devices / Re: Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze « on: September 11, 2012, 09:44:20 PM »   Quote from: TheCell on September 11, 2012, 09:26:37 PM
@FreeEnergyInfo
Thanks for the info of the successfully l__ped device.
Obviously Polysterene (here in the coax cable) is the key .
Romero mentioned in his site some remarkable results with pulsing
capacitors with polysterene as a dialectric. Did not speak out clearly
for some reason. Please put replication info as a copy in english here
on this site.
http://www.youtube.com/watch?v=-sEzNlzk-0Q&feature=em-uploademail
http://www.youtube.com/watch?v=9VDab7cIW1I&feature=em-uploademail
The coax cable is shorted in one end there. And its windings are in same way as all coils. The standing wave is being generated in nanosecond high voltage impulses to coax cable entrance from second generator and first generator provides main frequency to coil on same selenoid. The output is from third coil. (Remember TK 200W device with coax?)
The standing wave is very short pulses with high voltage from second frequency source and are angled in 90 degrees to transformer primary disrupting normal transformer function from primary frequency current source is the key to this device also is common concept to our NMR yoke device.
P.S> if you loose this bit you will never understand how NMR/TK/Yoke/Romanov and other devices work...
  solid state devices / Re: Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze « on: September 12, 2012, 09:28:15 AM »  Quote from: TheCell on September 11, 2012, 10:03:47 PM
@T-1000
NMR ?! He uses no ferrit core. Where should it happen ?
He uses a primary coil , on top of that a resonance coil, on top of that the coax and then the pickup coil.
I will never understand this completely, and don't have any ambition to achieve goals that I can't reach. Practical examples are the most adorables. And I think it can be simplyfied : A primary coil on that a coax triggered by a spark gap (of a plasma globe for example) and a pickup coil.
Another simple ou device would be a radio tube using the electron avalanche effect (like Tiger did)
..and I recommend using google chrome which can translate websites online.
NMR can happen in any matter and wires themselves are not exception.
The core got only bigger mass so you do not need large coils for same effect.
Quote from: verpies on September 12, 2012, 01:58:43 PM
Google translator does not produce technically accurate translations, and does not translate the text on the bitmap diagrams at all.
People who do not know the Russian language cannot benefit from the Russian forums.
They are at the mercy of native Russian speakers to summarize and post English diagrams and text here or other english forums.
Wesley already tried to translate - http://www.youtube.com/watch?v=amZxIpg5nP4#t=0h16m2s
EDIT: New URL - www.youtube.com/watch?v=QHBEHOOsxT4#t=0h21m12s
My comment on this:
As far as I see the second generator with coax cable winded on selenoid is between primary and output coil and there is resonant ballast LC coil is between coax and primary. The coax cable function seems to be disruption of main tarnsformer energy transfer from primary to output what got LC resonant ballast coil of ~4.6kHz in middle of those 2 coils. The coax cable is shorted on one end and nanosecond sawtooth pulses ~1khz are fed into its another end. That makes short living standing wave between primary and output coil. Everything else should be checked experimentally.
To test in short: wind primary on air core selenoid->wind resonant ballast LC coil in middle of selenoid->wind coax->wind secondary to output. Then feed main frequency into primary->resonate LC coil->connect load->see conventional transformer energy transfer->feed HV sawtooth impulses of 1/4 frequency and duty cycle <10%(spark gap peak waveform) into coax cable for standing wave pulses->loop back output into input->see if you can self run device. Avoid multilayer windings, test with single layer coils first.
Woopy, Itsu and a.king, this is a job for you TODO ASAP (http://www.overunity.com/Smileys/default/smiley.gif)
Cheers!
  solid state devices / Re: Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze « on: September 16, 2012, 02:46:30 AM »  Itsu, watsup:
http://www.energeticforum.com/renewable-energy/4864-donald-smith-devices-too-good-true-244.html#post208715
http://www.liveinternet.ru/users/edward_lee/ - Dally blog web page for those who are interested.
"Ну и Ñ,еперь по Ñ,еме , Ñ,о есÑ,ÑŒ по усÑ,ановке:
Ð' усÑ,ановке два генераÑ,ора , один генераÑ,ор раскачиваеÑ, преобразоваÑ,ель на Ñ,,ерриÑ,овом Ñ,рансÑ,,ормаÑ,оре для пиÑ,ания генераÑ,ора наносекундныÑ... импульсов и сооÑ,веÑ,сÑ,венно для подачи напряжения на каÑ,ушку, далее каÑ,ушка: сосÑ,оиÑ, из класÑ,икового каркаса и содержиÑ, 3 обмоÑ,ки, одна обмоÑ,ка - провод приблизиÑ,ельно 0,25- 0,3мм (Ñ,очно скажу Ñ,олько когда разберу ее с Ñ,очными замерами, когда-Ñ,о моÑ,ал мини Теслу, поÑ,ом она обрасÑ,ала дополниÑ,ельными обмоÑ,ками в Ñ...оде эксперименÑ,ов ). Ð"алее поверÑ... нее обмоÑ,ка проводом 0,65мм (назовем ее резонансная , она подключена Ñ,олько на конденсаÑ,оры 1,5мкÑ,, Ñ... 400в). Ð"алее обмоÑ,ка коаксиалом 50ом( ранее применялся в компьюÑ,ерныÑ... сеÑ,яÑ...) получаеÑ,ся биÑ,,иляр - конец обмоÑ,ки закорочен - нагружен на генераÑ,ор наносекундныÑ... импульсов.
Ну и сверÑ...у намоÑ,ана обмоÑ,ка для съема.
ОбмоÑ,ка съема нагружена на диодный мосÑ,, после диодного мосÑ,а сÑ,ояÑ, конденсаÑ,оры (ОбязаÑ,ельно не полярные! Полярные не выдерживаюÑ, и прошиваюÑ, или за несколько секунд надуваюÑ,ся!)
После выпрямиÑ,еля я нагрузил лампой 20 Ð'Ñ, ну и сооÑ,веÑ,сÑ,венно блок пиÑ,ания для самозапиÑ,ки.
Но еще, у меня блок пиÑ,ания зарабоÑ,ал Ñ,олько из чеÑ,ыреÑ... один, причем сÑ,арый АТ. Один не зарабоÑ,ал вообще, два бысÑ,ро вышли из сÑ,роя.
Ð"иодный мосÑ, между конденсаÑ,орами и каÑ,ушкой обязаÑ,елен! Ð'ез него неÑ, сÑ,абильносÑ,и рабоÑ,Ñ‹! Если кÑ,о Ñ,о будеÑ, меня учиÑ,ÑŒ сÑ...емоÑ,еÑ...нике - я знаю, чÑ,о в блоке пиÑ,ания сÑ,оиÑ, свой диодный мосÑ,, но Ñ,ак рабоÑ,аеÑ, намного лучше."
Here is translation
"And now about circuit:
The device has two generators. One generator excites inverter for powering up second generator of nanosecond pulses and powers up main coil. Next - the coils. The coils is winded on plastic core material and contain 3 windings:
First with wire about 0,25-0,3mm (will say exact measurements when I will unwind coils. It is ex-Tesla coil with additional windings added in later experiments). Next coil is on top of first is resonant coil with wire diameter 0,65mm (will call it resonant coil because it has connected only capacitor with capacity 1,5 micro farrads x 400V). Next coil is 50 Ohm coaxial cable (earler it was used as computers network cable) - it becomes bifilar because one end is shorted and second end is connected into generator of nanosecond pulses.  And the last coil on top is secondary for load.
The secondary coil is loaded to diode bridge and after diod bridge there are capacitors (must be unipolar! polar are not lasting long and get broken over few seconds!)
After diode bridge I did connected load of 20W and computer ATX power supply for self running circuit.
But additionally, only one from 4 power supply started to work and it was old AT PS. One did not worked at all and 3 blew up.
The diode bridge between capacitors and secondary coil is a must! Without it there is no stability in working circuit! If somoeone would try to teach me about circuits - I already know about diodes bridge in power suply but wit additional diode bridge it works better."
Good luck!
  solid state devices / Re: Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze « on: September 16, 2012, 04:33:51 PM »  http://www.liveinternet.ru/users/edward_lee/post235235326/
About fndings of effect:
ЭÑ,,Ñ,,екÑ, был замечен случайно , когда насÑ,раивал Ð".Н.С. в качесÑ,ве оправки для намоÑ,ки коаксиала использовал сÑ,арую мини Теслу.
но на ней была намоÑ,ана еще одна обмоÑ,ка проводом 0,65 и я пыÑ,ался на ней добиÑ,ься Ñ...орошей искры, насÑ,раивал Ð"НС и как Ñ,о подключил к ней емкосÑ,ÑŒ, и получил Ñ...ороший удар Ñ,оком. Совсем не поÑ...ожий на обжигающее прикосновение Ð'Ð' Ð'Ч. ТуÑ, дальше пошли эксперименÑ,Ñ‹ именно в эÑ,ом направлении. Я не преÑ,ендую, чÑ,о моя консÑ,рукция являеÑ,ся самой опÑ,имальной, но самое важное я получил, и буду рабоÑ,аÑ,ÑŒ дальше опÑ,имизируя и изучая данное явление и усÑ,ановку.
Translation:
The effect was found accidentally when I was tuning GNP (generator of nanosecond pulses). As base core I used old mini-Tesla. But on it I winded one more coil with wire diameter 0,65mm and I tried to get good sparks discharge on it and when was tunning GNP I randomly atached capacitor. Then got shocked by current unexpectly. This was not anything like touching high frequency secondary coil of TT. This is where there was more experiments specially in this direction.  I do not pretend about best construction of circuit but I did got most important thing in it and will be working more with device optimisation and learning about current effect and device
http://www.liveinternet.ru/users/edward_lee/post235235706/
Еще одна Ð'АЖНАЯ деÑ,аль- Ð'ЕЗ ХОРОШЕÐ"О ЗАЗЕМЛЕНИЯ - НЕ РАÐ'ОТАЕТ!!!!!!!!!!!!
One additional very important detail - without good grounding - it does not work!!!
http://img0.liveinternet.ru/images/attach/c/6/91/403/91403766_Generator.JPG
http://img1.liveinternet.ru/images/attach/c/6/91/467/91467647_100_6327.JPG
  solid state devices / Re: Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze « on: September 17, 2012, 11:51:45 PM »  http://www.liveinternet.ru/users/edward_lee/post237839624/
КаÑ,ушка
Ð'нуÑ,реннее усÑ,ройсÑ,во, Ñ...оÑ,ел написаÑ,ÑŒ Ñ,рансÑ,,ормаÑ,ора, но как Ñ,о назваÑ,ÑŒ Ñ,рансÑ,,ормаÑ,ором сложно.
1 Ñ,,оÑ,о - общий вид
2-Ñ,,оÑ,о -48 виÑ,ков
3-Ñ,,оÑ,о -59 виÑ,ков
4-Ñ,,оÑ,о -66 виÑ,ков
5-Ñ,,оÑ,о -70 виÑ,ков
ИÑ,ого: верÑ...няя обмоÑ,ка 83 виÑ,ка.
Под ней: коаксиал - 21 виÑ,ок RG50U.(Ñ,,оÑ,о 7, (http://www.overunity.com/Smileys/default/cool.gif)
Под коаксиалом 159 виÑ,ков провода 0,85 мм.(Ñ,,оÑ,о 9,10)
Ð"алее 475 виÑ,ков провода 0,33 (Ñ,,оÑ,о 11,12,13,14)
Coil:
The internal device, wanted to say it is transformer but it is hard to name it as transfomer.
1 photo - general view
2 photo - 48 turns
3 photo - 59 turns
4 photo - 66 turns
5 photo - 70 turns
Total: top coil 83 turns
Under it: coax cable - 21 turns RG50U (photo 7,8)  (translation addition: 50 Ohm computer network cable)
Under coax cable: 159 turns coil, the wire diameter 0,85mm (photo 9, 10)
Next: 475 turns coil, wire diameter 0,33mm (photo 11,12,13,14)
http://img0.liveinternet.ru/images/attach/c/6/91/684/91684490_100_6334.JPG
http://img1.liveinternet.ru/images/attach/c/6/91/684/91684491_100_6335.JPG
http://img0.liveinternet.ru/images/attach/c/6/91/684/91684492_100_6336.JPG
http://img1.liveinternet.ru/images/attach/c/6/91/684/91684493_100_6337.JPG
http://img1.liveinternet.ru/images/attach/c/6/91/684/91684499_100_6338.JPG
http://img1.liveinternet.ru/images/attach/c/6/91/684/91684503_100_6339.JPG
http://img0.liveinternet.ru/images/attach/c/6/91/684/91684508_100_6340.JPG
http://img1.liveinternet.ru/images/attach/c/6/91/684/91684509_100_6341.JPG
http://img0.liveinternet.ru/images/attach/c/6/91/684/91684510_100_6342.JPG
http://img1.liveinternet.ru/images/attach/c/6/91/684/91684511_100_6343.JPG
http://img0.liveinternet.ru/images/attach/c/6/91/684/91684512_100_6344.JPG
http://img0.liveinternet.ru/images/attach/c/6/91/684/91684514_100_6345.JPG
http://img0.liveinternet.ru/images/attach/c/6/91/684/91684516_100_6346.JPG
http://img0.liveinternet.ru/images/attach/c/6/91/684/91684518_100_6347.JPG
http://www.liveinternet.ru/users/edward_lee/post237842919/
"НаÑ,раиваÑ,ÑŒ с подключенным заземлением.
НасÑ,раиваеÑ,ся с помощью генераÑ,ора на TL пуÑ,ем подбора часÑ,оÑ,Ñ‹ и скважносÑ,и.
Tune with Earth ground connection attached.
Gets tunned with help of TL generator when tinkering with frequency and duty cycle.
So all details now, good luck in replication!
verpies
Quote from: T-1000 on September 18, 2012, 03:30:18 PM
Yes, NMR requires a polarizing field and another perturbing field oriented 90degrees to the former.  However how does the pulsed coaxial cable produce this perpendicular field, if it is wound parallel to the other windings ?
Also, wouldn't NMR be better with a deliberate resonating matter besides the plastic silicon dispensing tube (coil bobbin) and the copper wires themselves?
T-1000
Quote from: verpies on September 18, 2012, 06:30:23 PM
When you introduce standing wave its vector is 90 degrees from B field.
Deliberate resonating matter will make lots of noise (heat) and it would be stone age approach.
Please see www.youtube.com/watch?v=1OrPCNVSA4o for simple explanation.
The large magnet there is your current in transformer's first signal and small magnet on 90 degrees is your second voltage high frequency peaks signal from coax/other standing wave source on wires atom level.
In Dally device coax cable stands between primary LC circuit and secondary coil to output so it is same as small magnet in that simulation. Also in addition there is 1/4 of coil length sitting in same line with coax cable and is part of secondary coil.
Hopefully that explains something in general understanding for basic building blocks of OU devices.
