0 Members and 94 Guests are viewing this topic.
Tomtech29
Quote from: jake084 on August 30, 2015, 05:18:15 PM
Hello, are these pointed out measurements wavelength measurements or what?
Hello, please schemes in smaller sizes 700/600 pix. will be sufficient
-awarded points for you are presumed, length of what is needed for a particular coil
-and shortcuts such as 28 BNT. is the number of windings. This 6mm2 cross-sectional thickness (thick-wire).
Quote from: Tomtech29 on September 01, 2015, 06:00:08 AM
Right you are, and I apologize... since I'm one who usually complains about oversized pix. Edited to smaller size.
Whaaat?
AlienGrey
Is this the thick copper tube wound round the coloured tape sections ?
to find wave length  it's 300,000,000 / by the frequency 2mhz would be 2,000,000 = 150 meters simple ain it ;)  so how many turns or what length of wire have you on your katcher  if you don't mind me asking, as i have an idea why no one can get it to work.
NickZ
    TK, and all:
    All I could come up with is a single UF4007, to replace the two UF 306 I'm using as the cross-over diodes.
But I have lots of the IN4007, as well as the IN5408 diodes, if they would work for the cross-over diodes.
    I don't have anything like the MUR1560 diodes (600v, 15A), but I do have 2 MBR4045PT (45v, 40A) diodes and heat-sink, that may work instead.
    What do you or anyone else think would be the best way to go?
  MUR1560 diode specs:
  http://www.onsemi.com/PowerSolutions/product.do?id=MUR1560
   MBR4045PT diode specs:
   http://cs.utsource.net/goods_files/pdf/31/3136_MOTOROLA_MBR4045PT.pdf
AlienGrey
use the two of the top ones in your list. the MUR1560  tey are only steering diodes
Nick how many turns of wire do you have on your katcher coil and are you using the 2 mhz coil or the 1.736 mhz version ? i need to know as i think i have an idea whats wrong but i need to do some tests first as i might be being stupid but i don't know yet.
regards Alien Grey
