0 Members and 278 Guests are viewing this topic.
NickZ
  Well, at the moment I can show you how to burn up some fets...
  I've changed the UR 306 diodes which were my cross-over diodes, (which tested ok on a meter), to the smaller UF 4004, and a IN5380. As I don't have any of the UR4007, that are recommended in the diagram that I posted, and to which TK made some changes to.
  I also added another pair of brand new IRFP250N fets, as well.  Same thing, the fets are untouchable in seconds, and 200w load is nicely lit, although partially. The fets heat up even with a 10w bulb. It just takes longer.  No protection diode on the circuit yet.
  So, Yes, something is wrong, but, I'll find it, and when I do I get back to the scope shots, and such, or even before I find what's up.  Maybe it all working normally, I dunno.
  Hoppy: The effect has been shown by both Akula and Ruslan. The ability of a device to be able to have an effective feed back loop, is depended on this "effect", which has to be obtained, FIRST.  Otherwise, we're pissing into the wind.
  EDIT:  I just tried the device without any load, and without the two yoke secondary coils (28t, and the 3 turn coil) connected to the grenade. The new fets are still untouchable in just a few seconds, (with no fans or heat sinks). I'm just testing the Mazilli with no load, nor any output coils connected, at this time. And it still gets way too hot.  So, I'm looking for the problem.
Hoppy
Quote from: NickZ on September 02, 2015, 12:26:55 PM
;D Yes and we're knee deep in it already!
NickZ
Dog-One
Can you see any dead-time between the on-time of the two transistors?
If you can't, there's your problem.
AlienGrey
Nick what do you need to light a 200 W bulb of Katcher for, thought i read in Tesla's stuff the energy from the katcher the top end is maximum voltage and the bottom should be maximum current and thus has no where to go so it sinks into the ground via the ground link as the top end of the coil 'resonator' Katcher is or should be high impedance, unless the frequency is off then the energy goes back into the driver and 'bang'.
You do know how it works don't you ? again whats the lemgth of wire in your katcher ?????????????????????????????????????????????? eh ?
2mhz is 150 m 1mhz is 300 ect     ?    have you got a signal generator to see the peeks at the frequency of your grenade coil on your scope ?
