0 Members and 291 Guests are viewing this topic.
NickZ
  Why don't you mention, that that device was never a self runner, as it needed not one but two signal generators just to be able to partially light a 150 watt bulb. And any effect it may have had, has never been replicated by any of the guys who have tried to replicate it, nor even by the team that first made it.  1000w output (or 600w) was claimed but was never shown, just a single partially lit bulb, instead. And they all got sick from it from working next to it. Or so they say...
  No need to be proven???  Is that because no one could replicate it, including yourselves. What's the point then?
T-1000
There was two moments in Lithuania experiment:
1) Caduceus coil - created standing waves with unhealthy frequencies which obviously was also affecting biologial systems - http://nativedog.com/Effects.htm
2) The Yoke - created neutron radiation which did fallout as beta/gama radiation when neutron short life ended.
This tech is not for kids play and if you will be building, you was been warned to stay away from area of effect multiple times... ;)
T-1000
Quote from: NickZ on September 11, 2015, 09:36:10 AM
For one, the capacitor discharge can ever blow up bulb, it was fully lit.
For the second, why we should show self runner in first place then endanger the entire progress for following experiments? For us it was enough to show much higher rated load fully running than input was capable doing. The videos we shared was for showing power amplification effects not for making us proud with self runners.
AlienGrey
Yes Marcus, well said, I fully agree on you thanks to the posative help from all the Lithuanian and any others that have participated in developing this project so far as we try to learn and understand as we go ;)
Another chap Enjoykin, published this paragraph, that I'm a little confused over (witch isn't to difficult to do ;), any way the section i am referring to  Enjoykin said, both Akula's and Russians 'Device' was based on ( don't blame me if i'm wrong cus i'm asking ;) the Katcha (Tesla coil) is 3 times higher in frequency than the 50 turn grenade coil hence the divider chip from the sense coil on the Yoke coil to feed the PLL divide by 3 to 50 turn feed back loop grenade coil, but the EHT pulse to the center of the sine wave has to be 10 times the katcher frequency.
As an example frequency is just an example ;)
Example Katcher 1.5 mhz
50 turn Grenade coil 500 khz
EHT pulse 15 mhz
obviously multiple in frequency should be around 432 hz and not deviated ( the god frequency)
Could you please comment if this is correct, as we could do with input  T1000 ;)
May thanks Grey ;)
stivep
  Why don't you mention, that that device was never a self runner, as it needed not one but two signal generators just to be able to partially light a 150 watt bulb. And any effect is may have had, has never been replicated by any of the guys who have tried to replicate it. Nor even by the team that first made it.  1000w output that was claimed was never shown, just a single partially lit bulb, instead. And they all got sick from it from working next to it. Or so they say...
It was shown 600W load.
However the reason nobody touches it now is simple.
If you dead it is your problem, but if you dead knowing that this headache was as symptom of it, you are not only dead , you are stupidly dead.
I do not have headaches,  just few times in my entire life.
I do not have health problems just few times in my entire life.
I do not have drinking or smoking, nor any drug problems (never in my entire life.) ( occasional drinker, never drunk, few times close to be drunk, and occasional smoking)
The second time  when dealing with Colman  in presence of  another scientist , after few hours of experiment , I got to the same severe headache, but now  from left side of the head.
Whatever was the reason for that headache it was assigned to the same  set of side-effect phenomena as Lithuania Experiment.
The pattern was exactly repeating itself, however  pain was for few months at severity of the same  magnitude, only at this time causing impaired balance control.
Consultation with  doctor let me to believe that the  origin  of headache was the same, but region of brain  at this time was on the right  so  that is why part of the brain  responsible for balance controls was affected.
the deduction is :
In Lithuania Experiment - 10 second of exposure, at distance  of 2"* = 2,5 weeks of headache
* distance  of 2"*  -  radiation obey the inverse square law.http://www2.lbl.gov/abc/experiments/Experiment1.html
inverse square law applies accurately only when the distance from the source is several times greater than the [diameter of the detector. ( or area affected by  radiation)]
by that we can derive with calculation of Colman tube of equal energy level (keV) and equal directional strength at calculated square distance.
the same as nuclear explosion for  given  energy level of  gamma  100km form the impact.
The important factor for you to understand is :
if Colman was measured  at  the same  wavelength of energy level and cpm ( counts per minute) from distance of 2m ( 6")
it can be  as harmful  as nuclear bomb explosion  for exactly  the same wavelength of energy level and cpm ( counts per minute) from distance of 2m ( 6")
effecting the same cross-section area of  detector or human body .
it can be also  as harmful as Lithuania Experiment of exactly  the same wavelength of energy level and cpm ( counts per minute) from distance of 5cm ( 2") in time frame of 10sec,
No difference
for "safety of  discussion"
I keep this comment in  uninformed format.
Wesley
