0 Members and 720 Guests are viewing this topic.
NickZ
  I'll know more when I get the set of new probes, and WIMA caps.  But, for now, I think that the Mazilli is working as it should.
The 0.47uf WIMA caps are for the tuning of the 3 turns coil (6 turns, in my case), And also the 0.1uf HV WIMA caps are for the 28 turns coil. Not for the primary of the Mazilli, or it's tuning cap. Which I'm still not sure about, as to which one to choose, yet.
I don't think that the tuning caps for the primary circuit are as important that they be the expensive HV WIMA type, but I could be wrong.
    I still need to redo my Kacher circuit, as it does overheat the transistor if I don't turn down the pot on the base. And turning down the input through this pot, lowers the output at the antenna coil, by too much.
So, a new Kacher driver is in order, but I want to order and use some of the recommended 2SC5200 transistors for it this time.  Those transistors, and the 75v, 200w fets, are on my list, for my next order.
  Hoppy:  I hope that the HV WIMA caps will make a difference at the output, as well as the running frequencies. As they aren't giving them away, and some are much as $35, each?  Ouch!
  The magnetite magnet does not produce the sign wave, or saturate my core, as yet. The Mazilli driver will produce this type and shape of sign wave, with or without the magnet, or with a different value of the primary coil's tuning cap. The frequency will change, but, the wave shape stays about the same.
Hoppy
Quote from: itsu on September 13, 2015, 03:23:09 PM
Hoppy,
i understand that Nick will use the Wima caps for connecting in series with the 3 turn secondary, not for tuning the mazilla (but i could be wrong).
Do you think that this MOSFET signal is caused by the used capacitor in the mazilla?
I would expect a half sine wave like signal like in my screenshot (blue trace) not the continued peaks seen on Nicks scope.
What could cause that?  The egg magnet in the yoke which saturates the core/coil?
Regards Itsu
Hi Itsu,
I ran up my Mazilli before I posted and saw a similar waveform to Nick's with a couple of old and used capacitors, so the fact that Nick's cap is used and running hot, its ESR is likely poor and causing distortion to the output waveform IMO. Nick could look at the waveform on the other drain to make sure it is the same or similar to ensure that there is symmetry at the output.
Hoppy
NickZ
  The wave form is the same on both fets, but one has slightly more gain than the other. I've tried many different caps on the Mazilli primary, the wave form stays the same, although the frequency does change. The magnet does not change the wave form itself, nor is it really necessary, but it does improve the output, and can clean up the distorted wave forms.
The primary coil's tuning capacitor is NOT getting hot now, at all, as I've changed it to a higher voltage one. And, still the same wave form using another value higher voltage cap.
  I also have two diodes in parallel, on the 28 turns coil, as was shown in Ruslan's diagram, but they may not be the best choice. I'll try to remove them and see if there any difference. As one diagram has them pointing in one direction, and the next diagram shows them the other way around. So, who knows, if they are even really necessary there, at all.
I try to reproduce what I see in the diagram or videos, when I can, but some things are still confusing though.
nelsonrochaa
Quote from: NickZ on September 13, 2015, 09:10:06 AM
  quote from Nelson:
What you do with the BEMF  in you Mazilli ?
Way you and others insist eliminate BEMF  whith snubber configurations"  ?
        end quote.
   @ Nelson:
   I have not insisted on anything.  I have been following the correct Mazilli induction circuit schematic, which has given me a better output so far, lighting up 650 watt worth of bulbs, or more, than most of what the other guys have achieved with their much more complicated systems. I don't care about volt/amps, input or output measurements, etz...  I care about lumins, and obtaining enough use-able light levels, to light my house.
The idea is to connect the combined output of the grenade and kacher crt, back through the PS, and back to the input for self running. For this to work properly the right value caps are essential.
  The BEMF is not mentioned in the Akula/Ruslan devices. Or is it? As I don't understand all that is being said on the videos.
  As I understand it, the Kacher HF HV is combined with the magnetic current output of the induction circuit at the right matching frequencies. This combined output,  should be higher than using the Kacher circuit, or the Mazilli by themselves. So, it's this combination, that should be providing for the "extra power" being drawn in from the surrounding ambient, which should also provide for the proper self-running loop.
  My 18v zener "heaters" do not heat up at all, so I don't understand about the wasted energy. If they were not needed, they would not be in the schematic.  Or not?
Hi nick,
Happy that you able to tune your circuito Mazzilli😁 i just try explain you that subbers in most switching circuits are just "burning" part of power that could be used  to mantain the oscillation of the circuit.
How many will draw your circuit  without any load from your power source ?
Where will dessipated that power ?
About bemf:
Bemf : It will happens evertime .when a coil is compressed need return their own natural status like a spring .
Inflow , outflow.😀
Hoppy
Quote from: NickZ on September 13, 2015, 04:35:04 PM
As your cap is now running cool, try shorting out your chokes when the Mazilli is up and running to see how the waveform changes. The value of the inductor will affect the waveform shape.
