0 Members and 141 Guests are viewing this topic.
Dog-One
Quote from: T-1000 on September 16, 2015, 03:21:47 PM
http://www.allaboutcircuits.com/textbook/alternating-current/chpt-14/standing-waves-and-resonance/
Thank you T-1000.  I saw something in that link I had never considered before...  The mismatch...
We can tune the mismatch to force the standing wave by manipulating the resistances on BOTH ends, not just the terminating end.  Why this never occurred to me previously, I do not know.  I have so far always tried to minimize the resistance/impedance on the driver side; this severely limits the range of tuning possible.
starcruiser
RF theory, your slowly getting it...
the long wire is the ground plane... should be as long as the primary in radio / RF antenna, to make it simple.
Regards,
Carl
AlienGrey
Oh starting to wake up and listen to common sence are we ;)
It's not just RF, get your self a pencel and paper and draw the wave out on the paper starting with the zero crossing line we have nothing, so what have we got at the 1/4 wave  Hmm, the peek of ths sine wave (full power) and at half wave we have zero, figure the rest out ror your self.
magpwr
hi everyone,
I think not a single soul in this forum besides myself did not even bothered to ponder even once how Akula managed to obtain current movement to Earth with a single wire.
Nearly all of us tried with kacher in itself and found the hard way there is no current movement to Earth provided if you got a clamp meter at least.Unless you got a expensive current clamp meter for scope to prove me wrong.
Mere 0.2Amps was achieved using interrupter with the typical kacher to Earth using 30volts as dc source.
Members till now did not accept the fact that Ruslan is a B.S but the circuit from oleg is valid merely for the function but it does not result in FE.
It is simple to justify applying nanosecond on typical tesla coil where winding are wound side by side which greatly increase capacitance and greatly reduces the chance for the coil to pulse effectively  to Earth.
People have seen Tesla coil wound by Tesla himself.Have anyone even bothered even creating a tesla coil with sufficient spacing between each winding for primary coil in order to increase the 'Q' factor so that upon applying pulse or interrupter pulse it is able to properly deliver current pulse to Earth.
This video of mine  is just a small part of the reverse engineered version of the kacher coil from Akula video.I have attached my source of inspiration which was zoomed in version of Akula video.
Can't you guys even spot the difference in the kacher coil or you guys choose to be naive.
Only my reverse engineered version of Akula kacher is able to produce current reading to Earth using as low as 2watt of power for 7Amps as what was detected by Clamp meter.
34Amps to Earth is also achievable with the use of nanosecond interrupter provided you are using rectified dc supply from 12volts to 220volts inverter.
Not forgetting i am using 7kv high Q capacitor for the RF 68pf capacitor bought from digikey at $34 a piece for 1 tiny SMD.But variable capacitor 1nf 1kv or more is good for experiment purpose.
This is a challenge i give to you guys build a typical kacher and see nothing to Earth or follow my version provided if you can afford.
This is the second time i am highlighting this in this forum.
TeslaTransponder Device-Current movement to Earth Demo ver 1.0 http://www.youtube.com/watch?v=D5jRpPHfA1Q
Note this is just partial reverse engineering to show prove of current movement to Earth using single wire that's all.Please don't take this piece as a self running FE device in itself
I think that many members are very comfortable with mazilli and joule thief in this forum and not forgetting we do have many so called free energy consultants whom  offered nothing but merely gave loads of blunt advise to this point.
Tomtech29
Hi.
by the way, saying this oscillator circuit Kacher which purports to operate in a self runner I have never seen such a film, please provide a link:
I have the impression that too much went the easy way I do not know what will come out but since nothing good will bring to the project are Now the experimenter Proceed to comment A: how easy
all fundamental conditions have been violated
1) Size of coil and structure
2) The capacity and frequency
3) Logic controllers
4) And many useless theory not to mention the actual scheme
The latter is a metaphor to keep distance ...
