0 Members and 104 Guests are viewing this topic.
NickZ
   Gyula:
   Thanks for the tips.
   Here is the Kacher's signal after it has had some turns removed. Of course that drops the output, the intensity of the HV spark, and lowers the output seen on a CFL bulb, or neon bulb placed next to it.
   The scope is on the same .5usec setting as before.  I count 11.5 usec for the full cycle (.1usec sections).
From the 14 usec or so, previously.  I'll try to do the math, later.
   For now I just need to know if I'm getting closer to the 1.5 to 1.7mhz, or further away. Closer I hope.
   If I remove more turns, that will also drop the antenna's output to the grenade induction circuits. Which I don't think is what I need to do. As the 3 mm HV stream I was seeing before is now only 1 to 2 mm. And the HF stinging is also less pronounced.
gyulasun
Nick, from your present scope shot, I can count 11.5 from the 0.1 us small sections on the horizontal main axis, for one single cycle. This means 1.15 us for a single cycle time and the reciprocal value of this is about 870 kHz, went up from the previous 725 kHz.
(You may have counted it for a half cycle only (I mean your 6.8, which is 6 for me from the 0.1 us sections), it seems, and indeed it is nearly 14 for the previous waveform.)
Do you have a picture on the coil from which you removed some turns? Sorry if you showed it, I do not always follow this thread. A schematic you may have showed would also be helpful to comment on your findings.
Gyula
NickZ
  From the looks of it, in order to get 1.7mhz, or even more like 1:100 to reach 2.4mhz, 100 times higher than the induction circuits. I'd be left with too few turns for any significate HV effect,  I believe. I have already  removed about 3/4 inch worth of turns
  The Mazilli/yoke is tuned as good as I can get it, at this time, without the addition of the WIMA caps, which will be here in a few days, along with the new set of probes.
   I don't know if I should remove more turns at this time, in order to further raise the frequency, but somehow, I don't think that will really help. That Kacher circuit has seen better days, as I'm going to build up a new one, hopefully running at a higher frequency.  So, I may wait for my caps, and see what they do to my induction circuit, first.
   Itsu is the guy who has done some of this stuff, maybe he has a different thought about it.
   Here are two videos that Ruslan has posted showing the building and running of the same device that I'm trying to replicate, in my own way, ror any of you that may not have been following along on this thread.
https://www.youtube.com/watch?v=KthpwbTOcLo
https://www.youtube.com/watch?v=Dq4PvHhcPfI
  At about minute 20, Ruslan is showing on the diagram that the 168 turns coil (grenade output coil) has a SIGN WAVE signal.
  Not a square wave...
Hoppy
Quote from: NickZ on September 17, 2015, 07:46:45 PM
Nick,
From my experimentation, I found that to achieve a Kacher frequency of 2MHz plus, most of my turns had to be removed. I suggest that you retain the coil length that Ruslan shows but wind say 0.7mm ECW with space between strands as strongly suggested by Magpwr. I agree with Magpwr that from the video, it looks very likely that Ruslan spaced his coil turns.
As a point of interest, the TOPruslan circuit attached to Geo's post above shows a Kacher to PWM frequency ratio of 50:1 and according to Geo, this is a worker.
T-1000
These videos are old, just in 1st on 6:05 Ruslan said essential thing when pointing to middle between Tesla and grenade coils:
"If there is no frequency matching and you will start changing and will be going away from half-wave where we are joining voltage with current the system is going to switch off"
This is a reason why the background knowledge of RF theory is a must and the entire approach is from resonance on wave transmission point of view.
Cheers!
