0 Members and 150 Guests are viewing this topic.
NickZ
   T-1000:
   My 37.5 meter grenade output coil with 168 turns, is already "matched" to the thick 37.5 meter ground line, that goes into my water well that's in my back yard.
  So, maybe it's not 100:1, 1/4, 1/3, or even the  1/2 wave between the Kacher and induction circuit, but maybe another value, instead, for my particular circuits.
  The hunt for the illusive "effect", continues on...
  Edit:  I've removed some more turns, to try to match Ruslan's Kacher's secondary, (2.5 inch, or so width). And I've ALSO spread and spaced them out, as evenly as I could using the same former tube as I had used previously.
I will connect it back up to it's circuit, and upload some more scope shots of this new, soon.
itsu
Quote from: NickZ on September 17, 2015, 07:46:45 PM
  From the looks of it, in order to get 1.7mhz, or even more like 1:100 to reach 2.4mhz, 100 times higher than the induction circuits. I'd be left with too few turns for any significate HV effect,  I believe. I have already  removed about 3/4 inch worth of turns
  The Mazilli/yoke is tuned as good as I can get it, at this time, without the addition of the WIMA caps, which will be here in a few days, along with the new set of probes.
  I don't know if I should remove more turns at this time, in order to further raise the frequency, but somehow, I don't think that will really help. That Kacher circuit has seen better days, as I'm going to build up a new one, hopefully running at a higher frequency.  So, I may wait for my caps, and see what they do to my induction circuit, first.
   Itsu is the guy who has done some of this stuff, maybe he has a different thought about it.
   Here are two videos that Ruslan has posted showing the building and running of the same device that I'm trying to replicate, in my own way, ror any of you that may not have been following along on this thread.
https://www.youtube.com/watch?v=KthpwbTOcLo
https://www.youtube.com/watch?v=Dq4PvHhcPfI
  At about minute 20, Ruslan is showing on the diagram that the 168 turns coil (grenade output coil) has a SIGN WAVE signal.
  Not a square wave...
Nick,
i wound my kacher as mentioned here also (by AlienGrey) in a "spaced" way, meaning i have a space between each winding, see screenshot which i took from an old post here:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg423670/#msg423670
I wound the kacher with 2 wires, then lateron removed one of those wires creating this spaced coil.
It worked better at higher frequencies (1.8MHz), see the details in that post and further.
Regards Itsu
T-1000
Quote from: NickZ on September 18, 2015, 10:15:53 AM
   T-1000:
Well, there are at least few conditions you need to achieve before that hunt:
1) The standing wave have to happen on grenade coil with maximum reflection from the ground which will be matching in phase with wave from Tesla coil over capacitive coupling to grenade coil.
2) The frequency heterodyning effect for making Tesla coil high frequency wave stacking with low frequency carrier from induction heater circuit.
As soon as you will achieve standing wave condition it will be noticed by electronics starting to behave differently in area of affect. And also for the second condition the background information for why it is needed can be used from different type of experiments where the capacitor discharge is introduced to transformer additional windings in order to change its inductance on the reverse moments of sine wave:
https://www.youtube.com/watch?v=AL74zKXB0C0
(in the left of picture there is AC input mixing up with capacitor discharge from the right on wave peaks)
Tomtech29
Hi.
Nick how I can add something that I found a passage where Ruslan expressly said that in his Kacher does not work! and I explain to you that will diodes heat up and even heard him say something about falling into a stage do not know if he meant a shift sine wave in relation to grenade
I am convinced that once you bring a Tesla coil to the right frequency next step is to focus on the stage of obtaining energy while consuming minimal signal pulse character as we see here: https://www.youtube.com/watch?v=Aex2_M-lOeA
19:50 - 21:58
and very clearly and with conviction, he says he does not alternating (AC) voltage coil load-resembling a sine output from Kacher
because it will not work! the question is: deliver pulses to the primary winding of a sinusoidal signal only reaches to over run where the ferrite rod.
And on after(spiral) "antenna" has not shown that there is a guess that the belfry and that they will prove.
by this arrangement it is unique and for the initial work was based on nanosecond pulses
NickZ
  Itsu:
  I looked at your previous post.
  Here is what you posted:
  "The Kacher, in my idea, is to be tuned to the resonance frequency of the "Grenade/bifilar inductor/ground" which in my case seems to be
1.685MHz (which is a wavelength of 178m)
                                                end quote.
   Tuning both circuits, the Kacher and the induction circuits to the same running frequency was not the right idea, although it was worth a try. There are many theories about this, but, not much proof, one way or the other.
   The circuit that I'm working on should be tuned for around 27khz for the induction circuit, and 1.5mhz for the Kacher.
Or somewhere thereabouts. But, that's what I'm trying to find out.
   So, I just removed some more turns, and spaced out the remaining turns, as you've just shown. Just not as neat, and evenly wound. As it's not too easy to do, and I don't have more of that size mag wire, to double up on.
But a CFL bulb next to the antenna now lights more dimly.  It doesn't seam to like going that way. The frequency of course has been raised, but at the expense of a lower voltage output.
   Here's a couple of pictures,  showing the Kacher frequency, using the same scope setting, .5usec/Div, I counted 8  .1usec sections This is now down from 14 sections previously, when I first started tuning. And this is while connected to the antenna coil.  I'll try to do the math, no guarantee though.
  And the pic of my rewound and spaced Kacher secondary coil, below.
