0 Members and 78 Guests are viewing this topic.
NickZ
  If the 100:1 relation is really more like 50:1, then my 1.2mhz should within tuning range. But, it doesn't seam to be.
As I keep tuning I find new ways to improve the output, on the induction circuit as well.
Sometimes I can light all three 100w bulbs, but sometimes I have to unscrew a bulb to get the other two going, then connect the third. But, at times I can also light all three at once. Different frequencies, cause these different results.
My new 250 watt 220v bulb is still waiting to be tested.  I'm waiting for the "effect to show".  I feel that I'm getting closer...
  Ruslan's later device Kacher secondary coil, also grew in width, and he also placed the primary coil on the far left, not in the middle, as compared to his previous video devices. That is where he may also have spaced his secondary coil's winding out, perhaps, as his secondary coil is about twice the width that it was previously.
  Ok, Itsu, Thanks.
  I'll remove some more turns, and tighten up the wire turns, until I can get some clear spray to fix them down with.
I don't want to seal the winding until I finish tuning the coil. As I may have to remove even more turns, later.
AlienGrey
Itsu,
I think as Nick said the thing is to use lacquer not varnish ;)  I do know one should not use fiber glass tape as that does strange things at HF RF.
If i were you I would make or obtain a card sleeve, that could just move up and down the 50cm tube with the 'tuned copper wound length' could move up and down for tuning into the 'wave window' it self.
I did read the 4 turn CWW Katcher winding creates 'spin' or 'vortex'.
Alien
verpies
Quote from: NickZ on September 19, 2015, 09:26:41 AM
So, is there a problem with spraying varnish on the coil, as the mag wire already has some insulation coating on it.
IMO you should be fine as long as you do not get high-k dielectric between the turns.  Above or below the turns is fine.
Teflon carcass is better than polyethylene or polypropylene, too because Teflon has the lowest-k of all plastics.
GeoFusion
Will post this  one more time.
Seems most have just bypassed my very last post except Hoppy's attention towards it
See how the effect works and how he lets the arc take place at the 1000W halogen.
Almost at the very end of the vid you'll see it.
Yet the entire vid is valuable how he puts different loads and see how it works.
but what is most important here to see is when
a Kacher / Tesla coil Radient RF Arcs at the lamp, that is RF Radiant HV arcing with amps in sync!
Very hot and visible to see how bright it gets when it arcs and flashes.
Same as Ruslan's latest 4kW demonstration when he tries to connect the other 2KW load to the system
you can see how it heavily arcs while trying to fit the wire to the connections.  Urfa sanli has the same arcing.
That is the result that has to be achieved! that is it. This Works! don't you all see it!?
Yet in the vid of Urfa there is no loopback/feedback part. it's just to show how he gets the effect.
Very important Vid here :-\
https://www.youtube.com/watch?v=LeJfRlvUU2A&feature
Trying to point out Valuable stuff here, not here to play games.
All the information is on the net how and yet alot of tempered information too.
But some ppl try to help many get the right ones for them to continue on with the work.
   Cheerz~
NickZ
  Itsu:
  I've re wound the Kacher secondary, this time a bit more carefully. I also removed some more wire turns, several meters of the mag wire. And further spread the wires apart. Easier said than done...  Agreed!
  I count 6.8 sections of the 0.1us sections, with the scope set as before, using the .5us/Div setting. So, putting 0.680 into the CalTool, I get my 1.47Mhz. So, I'm almost to my expected 1.5Mhz minimum frequency starting point. And, I'm still getting decent output, but smaller streams, only about 2mm at the antenna.  No noticeable reaction yet at the bulbs, when connecting the Kacher to induction circuit, to be noticed still, even when using a 10 or 20w bulb.
  T-1000 is right in that I'll have to also tune the yoke 3 turns coil circuit to the Kacher circuit. As well as the 3 turns to the grenade output coil, all with an 37.5m earth ground connected. But, I'll need my WIMA caps that are coming in a couple more days, for that round of tuning.
The fun is just beginning...
   Geo: I'll review that video again.  And get back to you.  How's your project coming???
  Here's some shots:
