0 Members and 345 Guests are viewing this topic.
John.K1
Hi Nick,
If I right remember, the Kacher fires around the maximum POSITIVE peak of your current transformer. Remember DOGONE was suggesting to use current sense transformer to trigger your driving circuit of your kacher?  ;)
I said around the peak, as I remember Akula was speaking about this sort of things time ago and he fired the impulse right before the peak (which gives more sense) . Ruslan wasn't so specific about this.   Just make it tunable :).
itsu
Quote from: NickZ on September 21, 2015, 06:29:13 PM
  I've been doing that all along, ferrite in the Kacher as well as in the grenade coils, and magnetite in the yoke core, to test to see if I'm within tune-able ranges, but I have not been so far.
  Itsu: Should I connect the scope to the 0.47 capacitor to test the 3 turns coil/grenade induction coil frequency. Probe tip to the earth ground side of the cap, and the negative clip to the Mazilli negative input side?
Nick,
If your 0.47 cap is grounded at one side (which should be i think), then there you can put your probe ground lead,
the other probe tip you can put across this cap, across the inductor coil (other side then where the cap is connected) etc.
What you should see is a cap / coil in resonance, so a pure sine wave signal, but be aware it can be in the 500V pp range.
Now i see a 300V pp spikey signal, so you are not in resonance yet, so you have to tune the mazilla untill you have resonance.
If you had a push-pull arrangement driven by a TL494 or so, you simply could had to turn the tl494 frequency pot to tune, now
you have to manipulate the mazilla somehow to get the inductor coil in resonance.
Here a link to way back in this thread where i show the resonance signal across both the 0.47uF cap and across the inductor coil,
it is in the 500Vpp range http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg422739/#msg422739
Be aware that you use your (grounded) ground lead of your scope in the right place as to not short out something!!
If you have a signal generator, you can find the resonance frequency of your 0.47uF cap / inductor coil, then set the mazilla
close to that and fine tune for resonance.
Regards itsu
Jeg
Quote from: John.K1 on September 22, 2015, 02:36:37 AM
A Hall sensor inserted in to the plastic tube will also do the job! ;)
Dog-One
The goal being to get something like this on your scope.  The whole thing needs to be synchronized.  In the later work Ruslan did, he uses a burst of about ten pulses instead of a single pulse.
T-1000
Quote from: Dog-One on September 22, 2015, 06:13:25 AM
Here is my opinion on general thing:
To be more precise, the same method was used by Stanley Meyer for HHO production. All things go down to nuclear level explosive power with pulse trains... :)
https://en.wikipedia.org/wiki/Stanley_Meyer%27s_water_fuel_cell#/media/File:Water_fuel_cell_circuit.png
With purely magnetic and electric fields it is same story just we are harnessing charged particles flows there for making electricity.
Cheers!
