0 Members and 150 Guests are viewing this topic.
itsu
Thats very right Dog-One, i measured up till 50A pp here:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg422291/#msg422291
Thats why you need good Wima capacitors there, high voltage and high current.
Regards Itsu
NickZ
  Just getting used to using both scope channels now. And getting a view able signal from both channels at once. Not that easy to do.
   I haven't taken any scope shots yet as I've been tuning the 3 turns coil, which was 6 turns, and I've removed 2 turns and it's now at about 4 turns of he thick 6mm insulated wire. My grenade induction coil is still at the 12, 12 turns, from when it was running on 12v, but as it's running on 24v now, I will probably have to rewind it also with more turns.
  The new red WIMA 0.47uf tuning capacitor on the 3 turns coil is 4 times the size of the previous yellow 275v 0.47uf capacitor that was on there before, (image below). So, I'm looking for those big angry sparks, when shorting it out. But, I'll need to remove some turns on my Kacher, first, as its frequency is now just a bit too high and the 1mm streamers are weak, at 2.5Mhz.
I'll probably need to go to down to about 2.4Mhz on my Kacher's secondary coil frequency, to see if there is any improvement there.
  Itsu: I'll take some scope shots of the grenade's 168 turns coils running frequency. Let me know where should I connect the probe leads to be able to take a reading? And is this reading is to be taken with and without the Kacher active?
  I'll watch your video now.
John.K1
Hy guys,
I can see we try to replicate the effect without the knowledge of what we are  looking for. My question is-  where the energy comes from?  What brings that extra energy in to the system? Do you know?  DogOne- have you tried to synchronously pulse Tesla over the current transformer and have you got more Out than In? My opinion is there is no way to have OU justt running two frequencies or bursts of impulses over each other.  The output will be always the sum of energies minus Losses  = <1.
I have my work on this device stopped for while because I am looking for the missing piece.  I am looking everywhere.  And there is something what pay my attention now.  Two independent designers speaks about how Tesla works. They say correctly designed Tesla "sucks" the energy in to its top capacitor - opposite of radiation. The other guy shows the principle of Tesla example ,where the question is how to get a boat from one side of the lake to the other side - not any rope to pull it. Just have in the middle of the lake a drain and use only small energy to open that valve. The water will start flow and so does boat (or many boats)    Now The question - Is our  Grounded Tesla that drain? moving (or accelerating) charges or fields from surrounded environment through our collector?  Is the ground where it goes? Thicker the ground cable, more volume we can drain in given time?   Should we focus first on proper design of our Tesla?  Ho to calculate right/correct capacitor (its surface)?
Just something to think about.
itsu
Quote from: NickZ on September 24, 2015, 02:48:00 PM
Well, i have no idea which diagram you currently are following, but if the 168 turn grenade coil is grounded at some point, there you can put your ground lead
of your probe, the probe tip on any other point you want to probe.
But as this grenade coil is hooked up via the yoke secondary (28 turn, 38 turn ??) and being inductively coupled to the inductor coil, it will show
the same frequency as the inductor coil and thus the mazilla (24KHz?).
But as this is not its resonance frequency it will not be in resonance.
Its resonance frequency will be in the MHz range as i have shown before and the only way to find it is to hunt it down with a signal generator and your scope.
Up till now you have avoided to answer my hinted question if you have a signal generator, so i assume you have not which will make it difficult for you to
hunt down the resonance frequency of your grenade (with ground).
As i understand it, the purpose of the grenade coil is to mix the HV pulses it receives from the kacher on its resonance frequency (same frequencies in the MHz
range) with the 1:100, or 1:60 or 1:50 relationship (KHz) high current pulses from the inductor coil and pull from ground the extra energy.
Regards Itsu
NickZ
    Itsu:
    I think I understand what you mean when you say that the Kacher and the 168 turns coil should be running at the SAME frequency. Since mine aren't doing so, I didn't know what you meant.
   As my Kacher frequency 2.4Mhz (2.5mhz) is no where near the same frequency as where the 168 turns coil is running at.
    Let me see if I understand:
    So, first, we need to find the best resonant frequency or peak using a signal generator, of the grenade's output coil.
  Yes, I have access to a SG, but it's not mine, although I can borrow it, but it has no probes. Can any of my scope probes work on the signal generator? I have a probe with twin crock clips, also.
  Then second, the Kacher needs to run at the same frequency as the best grenade resonant frequency (but not the normal running frequency), of the 168 turns coil. So that the Kacher's HV signal will activate and trigger the grenade's output coil at it's favorite sweet spot. This is what had me confused. I get it now.
   And third, the Kacher to grenade/inductor coil frequency ratio needs to be something like 100:1, 50:1, or so. Which for my set up would be the Kacher running at 2.4Mhz, and induction/coil/3turns coil running at 24Khz, or so.  Correct?
  I'm trying to understand what has to happen, and how it has to be done. So, John won't get on my case about not knowing what to do before hand, even though it's true.
