0 Members and 296 Guests are viewing this topic.
Jeg
Hi guys
I'd like please to rectify the signal out of a Kacher's secondary. The freq will be about 2MHz but i can't estimate the current peaks. I look that the diodes SF38      (http://www.farnell.com/datasheets/1697469.pdf)   are 600V at 3A max I(AV). With a bunch of them in series i am ok in respect with voltage. Do you think that 3A is enough for this task? What about the temperature? Are they gonna handle this? Do you have something cheap and good to suggest?
Thanks
Jeg
Hoppy
Quote from: forest on September 26, 2015, 03:29:45 AM
Your main mistake is the searching for HOW IS IT DONE. You must understand WHY IT IS DONE THAT WAY.
The sweet spot need careful adjustment and every circuit is different. You cannot replicate something you don't understand how to tune and WHY. Of course I'm talking theoretically.
Agreed. Are you replicating the device?
forest
Quote from: Hoppy on September 26, 2015, 07:52:20 AM
No, not yet. First I'm building my own devices and learn.I will return later to let you replicate Akula-like devices.Or Kapanadze -like or whatever - IF I would learned HOW to use the principle.
John.K1
Forrest, Hoppy   that's exactly what I mean.  As I said before, I put my Ruslan's replication  on hold and do small experiments with radiant charging , experiments with cap/coils, effect of grounding on the system etc.
With respect to what Acula says in that movie the most important element is an "inductor" between the Tesla and it's Antenna to get sharp face pulse (He says his pulse shoots over 30KV)  So, can you replicate this? Actually, is it even possible to sharp the front face of the sinus wave by inductor??
NickZ
  The tuning principle and proper turning procedure have already been stated, and shown on the Akula video that I just posted the link to. If you have a signal generator, scope, etz...
  Ruslan has his own way of obtaining the same results. If you understand Russian you can do it his way, or Akula's way.
  If you don't have a signal generator, then you, like me, will also have to find your own way to do this. Which can take forever, and is a very slow approach.
  If you can borrow a signal generator, to see what the frequency is of the grenade's output coil, at it's highest resonant peak, you then can have a starting point. Which is what I may have to do, also.
  Here below is the running frequency readings of my 168 turns coil, connected to the circuit, but not using the Kacher crt, as it is  off.  And also the readings of the frequency at the 0.47uf WIMA 1600v tuning capacitor, (second image).
  The scope settings are the same for both of the above readings taken. Which are also shown in the single pic of the scope setting image, below, (third image). And both readings are  using only channel 2 of my 100x probe.
  I see 2 sections at the .1ms setting, for the 168 turns grenade coil.
  I see 7.6 sections at the same .1ms setting, at the 0.47uf capacitor.
  The device is also earth grounded at the the input side of the 168t coil, and the Kacher transistor's emitter is also grounded to earth ground.
