0 Members and 164 Guests are viewing this topic.
NickZ
   TK:
   Yes, those 4 things would be nice to have.  Someday, one step at a time. But, like yourself, I don't have much room.
   The difference of using the same fets, and changing a few snubber components to match what the TL494 board requires, does not sound like mayor surgery.
  Does it matter if the Mazilli becomes something other than a Mazilli circuit?  No, not to me.  However, I'd still like to see what the Mazilli/yoke/grenade/Kacher combo that I've been working on can do, at resonance. So, that's the plan, for now.
And, it's good practice, resonance sniffing...  but, I think that I should also try to replicate Ruslan's same running frequencies, to see if I get any effect there. As he has already found them (those resonant points), for his device. And, it's the same 168 turns grenade coil, and 37.5m ground line that I'm using, or similar.
Except for my 12,12 turns bifilar induction coil, which may need a new rewind, or,  maybe not.
I can also still remove another turn off of my 4 turns coil, and have just 3 turns, if needed to tune that circuit.
   At these prices for the ZVS drivers, $12,  it makes me wonder why I even bother to build the Mazilli. There's different models, also.
http://www.ebay.com/itm/ZVS-Tesla-Flyback-driver-board-Zero-Voltage-Switching-f-FBT-inductive-heater-/331551087678?tfrom=331561472454&tpos=top&ttype=price&talgo=undefined
Hoppy
Quote from: NickZ on September 27, 2015, 05:45:12 PM
  Hoppy: I get it, already. But, everything takes time.  It's free remember, and I just got notice that my clip lead scope probes will work on the signal gen. So now, I have to study up a bit on just how to use a SG, etz...
Assuming that I can still borrow one, as I don't want to have to buy one just for a single frequency test on the grenade coil.
If Ruslan is using the frequency of 1.7Mhz to drive the Kacher, for his previous device. Then,  THAT is the resonate frequency of the grenade's output coil. Or it should be. Right?
Nick,
Its more likely to be a strong harmonic of the grenade coils natural higher resonant frequency. As Itsu has guided you, you can find the resonant frequency of your inductor combo without the signal generator but its very likely that this will need to be altered to match a suitable low frequency at a 50th, 60th or 100th division of the grenade coil frequency.
Thaelin
Does that mean that TK will then fund the parts for all the benches out there?
Waiting
verpies
Quote from: TinselKoala on September 27, 2015, 08:45:05 PM
A basic electronics workbench needs to have at very least these 4 fundamental instruments:
Oscilloscope
Function (aka Signal) Generator
DMM,   TRMS if possible
Voltage Regulated, current-limiting adjustable Power Supply (CV-CC PSU)
...and more advanced workbench?
VNA? LRC bridge? RF wideband analog amp?
magpwr
Quote from: TinselKoala on September 27, 2015, 08:27:32 PM
It won't be a Mazilli then. The Mazilli/Royer type oscillator's frequency is determined by the inductance of the yoke or other coil, and the capacitor that is across (in parallel with) that coil. It is an _autoresonant_ circuit that automatically runs at the resonant frequency of the tank circuit formed by the L of the coil and the C of the capacitor.
For the Mazilli (without other oscillator):
If you had an inductance meter and a capacitance meter you could measure these values and plug them into the Resonant Frequency Calculation here:
http://www.1728.org/resfreq.htm
and the result would be in agreement with what you measure on your scope. Conversely, say that you know your capacitance accurately (because it's marked on your new capacitors.) Then you can plug in the cap value, and the measured frequency, and the calculator will give you the inductance of your yoke coil. Now that you know the inductance of the yoke, you can _calculate_ the capacitor value required to give you whatever frequency you need, using the same calculator. Or vice-versa, known capacitance and desired frequency means you can calculate the required inductance. It's an equation with three parts: f, L and C. If you know any two values you can find the third by the Calculator.
You can certainly drive your Yoke coil with some other driver architecture, like the 494 module driving an H-bridge or etc. but it won't be a Mazilli and it won't automatically achieve the resonant frequency of the L-C tank. In fact if you try to drive an L-C tank circuit at some frequency other than its natural resonant frequency... strange things will happen. It will be like trying to push a child on a swing, at some other times and rates than when it's at the top of the swing each time.
hi TinselKoala,
I have already given up in trying to teach an old dog new tricks.Maybe you would have better luck with the intention help someone not to use a Mazilli circuit which i have mentioned few times before it is a pain to tune the frequency.
But i hey i stop anyone from doing any kind of repetitive experiment which they "feel" it's right.
The SG3525AN is a better PWM generator than a TL494.The source-sink is around 450mA for SG2525AN but for TL494 it's mere 200mA.
If the choosen mosfet gate capacitance is below 2000nf.The SG3525AN is able to provide a nice square waveform directly to mosfet and without distortion.
