0 Members and 272 Guests are viewing this topic.
itsu
Quote from: John.K1 on September 28, 2015, 03:48:26 PM
Thanks TK,
I do sometimes measure the resonance as you say, just couple turns of wire around measured device. I only do not use the resistors as you suggest- I probably should.
Yesterday I just decided to give it a try as seen on Akula's channel and logically it should work -and I decided to test it using FTT.
My cap coil is actually two aluminium foils forming capacitor on the 40mm tube - but connected as a Tesla bi-fillar coil. In other words it is Tesla bi-fillar  coil made of aluminium foils (around 7 turns).
I have measured it now as you suggested and I have still the same result. What ever signal I use FTT shows the harmonics of the pitch of given frequency. Isn't it weird?
John,
i also tried it the Akula way, see screenshot below, but it did not work for me either.
The sweep is flatlined all the way, no resonance peaks seen, just measuring the FG output,  the attached coil has very little influence.
Regards Itsu
John.K1
Hi Itsu,
So I am not only one. :D
It might look like my question or device is a bit of this thread, BUT  in the Akula's movie he shows the coils under the Tesla's antenna and he ask him self the question " how we will charge (collect) the energy on this CAPACITOR  which has 15 turns (if i right understood :)   )
The device I measure is for different project but I want to try it as that Capacitor /coil showed in the movie. I need to know what is it's resonant frequency so I can adjust my test Tesla coil.  Sorry TK I didn't take a look at your movie yet. I will do it soon.
regards,
itsu
Quote from: NickZ on September 28, 2015, 01:20:28 PM
   The 1.7Mhz of the Kacher must some how be in sync up with the 37.5 meter 168 turns grenade output coil, as well as with the grenade inductor (resonator) coil.
  Does any one have a signal generator, and a 168 turns, 37.5 meter grenade coil built up, that can test the self resonant frequency of the coil?
  I added some turns back onto my Kacher secondary coil. But, I still just a have 1mm spark, and no streaming.
  I'll take some new scope shots, soon. I didn't like the ones that i just took.
Nick,
i "scanned" my grenade coil (168 turn coil) for resonance, and i used the inductor (bifilar) coil around the lower part of this grenade as injectionpoint from my FG.
Also the antenna with the ferrite rod coil connection to the kacher was installed, so these all could have influenced the resonance frequency.
But as you can see i have a distinct resonance point around 1.4Mhz with, i think, a 3th subharmonic visible at 460Khz
So in my case i would try to set the kacher to this resonance frequency (1.4Mhz)
But as now the inductor (bifilar) coil was not connected into the circuit (with the 3-turn coil, 0.47uF cap etc) things (resonance) could
shift once you hook it up, so its not that simple and tuning still will be needed in the life system.
Regards Itsu
Hoppy
Quote from: itsu on September 28, 2015, 04:04:08 PM
John,
Regards Itsu
Nor me Itsu. I tried this yesterday and also found it flatlined.
Quote from: NickZ on September 28, 2015, 03:33:00 PM
   TK: 19 divided by 0.000008= 2.375Mhz  Correct?
Yes, correct. I hope you can see where the numbers came from on your scopeshot. If not, just ask and I'll be glad to explain. Forgive me if I seem a little "testy" at times.
    Sorry about the bad scope shots, I'll do it again.  I took the pics down, and I'll replace them with new ones.
The images weren't "bad" just a little hard to see what needed to be seen. No worries, we got it done. If you have some kind of simple graphics program you can put the relevant knob setting information directly onto the picture of the scope screen as text; this will also help you when you go back and look at your various saved scopeshots.
    There also seams to be better and worse frequency levels for my Kacher circuit to run at. But, I'd like to get back seeing the 3mm streamers, and HF stinging, that I had observe previously.
Don't forget that high voltage overcomes insulation. You could be leaking, shorting, spraying corona from sharp points, etc. Working with HV HF takes practice and care. Layout is important, proper spacing is important, and I've learned that insulation cannot always be trusted. Once a carbon trace forms it will only get worse; pinholes in plastic insulation on wires can give you fits trying to track it down....
