0 Members and 348 Guests are viewing this topic.
NickZ
    T-1000:
   I'm not messing with anyone. I've been messed with, and there is a difference. I'm not trying to make you out to be an idiot.
If I were, you would not like it either.  And magpwr, has been insulting me several times before. I've taken all I can take, and he just keeps at it.
  Sorry to the rest of you.
  But if this keeps up, I won't put out the other cheek.
   Back to the subject at hand.
   Ruslans previous Kacher circuit like the one I will build soon, doesn't have nor need the sharp pulsing to observe the effect.
Or not??
   I feel that if the magnetic induction circuit is running at the right frequency, and the Kacher is also pulsing the grenade's coils (both) at the right frequency, and all the coils are built correctly, and in sync, the effect will show itself. After that, I'll look into sharp pulsing, PWM, and frequency controllers, PLL, etz...  to improve on the "effect".
  Theory as to where any additional energy comes from can then be looked into, and proven, or dis-proven.
  So far some guys have been trying to study and understand, and may possibly even try to replicate at some point, one of the worlds most involved, and complicated circuits.
  I'm starting from the basics. Induction circuit, and Kacher for the HV.
  Sorry again, for any hick-ups and burps.
Jeg
Quote from: TinselKoala on September 29, 2015, 11:20:45 AM
Actually I believe just the opposite. That is, the circuits _do_ work; that is, they produce pulses, can make HV, etc. What they cannot do, and what Ruslan and Akula are faking, is the self-running, excess energy part.
Circuits are working very well and they really do even in a complicated way what they designed for. The problem is at a conceptual level and not engineering. Without knowing the target what someone can expect? By loading with high frequencies power signals, drives to nowhere. It is a conventional system, and output can be calculated with conventional expectations. This doesn't mean necessary that device is fake. It could also means that Akula and Ruslan still keep good their secret by false propaganda and misleading. The most common is to make you believe that system doesn't work because you didn't hit the right superspot and combination of harmonics.
NickZ
  It would be better as concerning the last Akula video that I just re-posted, if Akula used the actual grenade coil, with the Kacher circuit, inductors, and earth ground lines connected. Then show the signals, frequency and voltages, of all the circuits, when everything is tuned and working, and when it's not in sync. Than to show what happens to a different coil, at resonance.
  Itsu: Thanks for doing the tests on your grenade coils.  The 1.4Mhz that your scope is showing a resonant peak on, is also close to what I noticed as the best output from my kacher circuit. Showing 3mm streamers, and stinging HV.  I think that that happened at around 1.2Mhz for me.
   I'll plan the next step.
   Thanks again.
Hoppy
Quote from: NickZ on September 29, 2015, 12:46:32 PM
Nick,
I don't see it as complicated circuit. To the contrary its an interconnected group of fairly conventional electronic circuits. Its the mode of operation that appears complicated because many of us do not yet understand how these fairly conventional interconnected circuits can result in a self-running device.
You need not apologise for any hick-ups and burps. As I see it, currently none of us here, including Magpwr, can justifiably claim a superior level of knowledge on how best to build this contraption. Some of us can be fairly criticised for pushing our ideas and suggestions rather too strongly but that's to be expected on a forum with many different contributing personalities.
NickZ
  Itsu:
  Do you think that I should change my Kacher's secondary to the 1.4Mhz level, to see what happens there? As that will probably be my next step, after viewing your test results.
  Like I said, my time cost me nothing.  And even poor results are no big deal, and I'm not giving up just because I don't see what I was looking for.  I'll just keep looking and sniffing out those syncs, until I find them.  I know they're there.
  In this video from Ruslan he is explaining about different frequencies, and relations between the different coils, and how they integrate with the Kacher circuit.  Of course, I don't understand it.
  My grenade output coil is not wound like is shown in this video, as mine has both sides of the 168 turns coil connected to the 28 turns of the yoke, through a wima 0.1uf tuning cap in parallel, and directly out to the 3 100w bulbs, not rectified, as yet.
Diodes that I had made a full bridge rectifier at the grenade's output,  melted their solder joints. A couple of times. So, I haven't got suitable diodes. But do I really need them? As my PSU is a 110v to 220v AC input.
  Funny thing though, how Akula and Ruslan using similar PSU units, can obtain a feed-back loop using them to output 1000w- 2000w output at the bulbs.
  Ruslan's video, notice also how he is always changing the schematics or diagrams, as he goes from one video to the next.
  https://www.youtube.com/watch?v=0CUVsS56xqo
