0 Members and 632 Guests are viewing this topic.
Jeg
Thank you Nick for posting again Acula's video. It seems that i have messed on somewhere when i was using this technique. I will try today to repeat it using my new oscilloscope. I hope it will work as it looks like very straight forward and without messing with inter-capacities while triggering it!
itsu
Quote from: NickZ on September 29, 2015, 05:01:30 PM
Itsu:
  Do you think that I should change my Kacher's secondary to the 1.4Mhz level, to see what happens there? As that will probably be my next step, after viewing your test results.
  Like I said, my time cost me nothing.
  And even poor results are no big deal, and I'm not giving up just because I don't see what I was looking for.  I'll just keep looking and sniffing out those syncs, until I find them.  I know they're there.
  In this video from Ruslan he is explaining about different frequencies, and relations between the different coils, and how they integrate with the Kacher circuit.  Of course, I don't understand it.
  My grenade output coil is not wound like is shown in this video, as mine has both sides of the 168 turns coil connected to the 28 turns of the yoke, through a wima 0.1uf tuning cap in parallel, and directly out to the 3 100w bulbs, not rectified, as yet.
Diodes that I had made a full bridge rectifier at the grenade's output,  melted their solder joints. A couple of times. So, I haven't got suitable diodes. But do I really need them? As my PSU is a 110v to 220v AC input.
  Funny thing though, how Akula and Ruslan using similar PSU units, can obtain a feed-back loop using them to output 1000w- 2000w output at the bulbs.
  Ruslan's video, notice also how he is always changing the schematics or diagrams, as he goes from one video to the next.
  https://www.youtube.com/watch?v=0CUVsS56xqo
Nick,
allthough we seem to have a similar grenade coil (168 turns), all other parameters (wire used, former dimension, spacing etc. etc.) will be different causing you to have
a different resonance point, especially if you say that you have a wima 0.1uF capa in parallel.
This will have a hugh effect (when was this 0.1uF cap (or ** as it shows in the latest diagrams) introduced, it was not there last year??) on the resonance frequency.
For you to change the kacher is not realistic, you first need to know some resonance frequencies of your coils / combo's.
Else it will be like shooting in the dark with blinders on.  You got to have some light/sight to be able to aim.
The 1000W - 2000w output at the bulbs are coming from somewhere else, not from the PSU units.
The PSU units receive only a part of the feedback, enough to maintain there working status.
Regards itsu
Hoppy
Quote from: itsu on September 30, 2015, 05:01:20 AM
Nick,
Regards itsu
I too had not realised that Nick was loading his 168 turn grenade coil with a 100nF cap!. He has presumably done this just to get his bulbs to shine brighter. This of course precludes him from carrying out the tuning procedure so far discussed to establish the natural frequency or strong harmonic of the grenade coil with the cap connected. However, the fact that a cap appears across the ALLEGGA circuit diagram, begs the question as to whether it is necessary but has simply been omitted from Ruslan's circuits for some reason. Has this capacitor ever been shown on any of Akula's circuit diagrams?
As pointed out many times, these statements about power output as perceived on videos are meaningless without measurement and we have never seen output power measurements from either Akula or Ruslan.
NickZ
  As I had mentioned, Ruslan is continually changing his device, and schematics. This can make it a bitch to try to keep up with.
  The 0.1uf 1000v capacitor is part of the two needed WIMA tuning caps. This one is for the 168 turns coil circuit, placed in parallel, and the 0.47uf 700 to 2000v tuning cap is placed in series at the 3 turns/inductor circuit.
That 0.1uf cap does change the output to bit higher level, with a corresponding brightness increase as seen at the bulbs. It was the only tuning cap that actually raise the output of the grenade's output coil circuit, on my device.
   Ruslan is now using a 0.15uf wima cap, instead, when he added 2.5 meters additional wire to his now 40 meter grenade coil, and also brought the inductor running frequency down to almost 1/2 of of what it was running at previously, from 27.3khz (now at around 15khz). And, I suppose that that was also using a re-tuned 40m earth ground line to match.
  Hoppy: I don't think it's going to be that easy to measure and compare the input and output values of this device, when it's self running, like you would a normal closed circuit. Unless it stays at being just a closed circuit, running at around only 70% efficiency, or less.
NickZ
 quote from Itsu:
''For you to change the kacher is not realistic, you first need to know some resonance frequencies of your coils / combo's.
Else it will be like shooting in the dark with blinders on.  You got to have some light/sight to be able to aim."
        end.
  Itsu: Yes, I know. But, if I can get closer to seeing which way to go to tune the circuit, I can be going in that direction. Until I hit it, as I do know what I'm looking for. I just have not found it yet.
  The grenade coils, yours and mine,  should be close enough in resonance, if they are both 37.5 meter long. But, my inductor coil at 12, 12 turns may need more turns added, for it to have more impact on the 168 turns output coil.  When previously running the inductor from the 12v input source, adding more turns to it did not seam help. But, at 24v, who knows.
  Any way, I'll still try to obtain a SG, if I can.
