0 Members and 596 Guests are viewing this topic.
QuoteFunny thing though, how Akula and Ruslan using similar PSU units, can obtain a feed-back loop using them to output 1000w- 2000w output at the bulbs.  Ruslan's video, notice also how he is always changing the schematics or diagrams, as he goes from one video to the next.
That's right. Have you ever counted up how many different circuits and devices that Akula/Ruslan have presented between them, that all "work" to produce self running and energy from "somewhere else" ?  This is what I call a violation of "Conservation of Miracles".....
And yet, nobody else has managed to make them work. Something is missing, from every description and every video and every "Stivep" translation and interpretation. Something that Akula and Ruslan definitely do _not_ want you to find out.
QuoteThe 1000W - 2000w output at the bulbs are coming from somewhere else, not from the PSU units.
Absolutely right, and as long as nobody knows just where that output power is coming from, your efforts to reproduce that effect are going to be fruitless. However, as long as you are having fun and learning, you can at least enjoy your work.
T-1000
Quote from: TinselKoala on September 30, 2015, 10:35:58 AM
The trial end error is a way to go.
The Yoke device did not appear working from day #1 as well, we had to reach to that knowledge by just trying small "side effect" on heating in the middle of ferrite rod then trying to convert the waste heat into useful output on large air coil and then finally concentrating onto effect on pure ferrite core... ;)
Also even N. Tesla had hints on effect for ball lightning which -is- concentrated energy and his famous quote about stray frequency in main frequency of power lines which destroyed power substations way back to his time is something to look at. When using that effect properly we can extract energy into useful form instead of just doing destruction.
Cheers!
Hoppy
Quote from: T-1000 on September 30, 2015, 10:47:50 AM
Cheers!
You are winking again, making out that you know Ruslan's secret to self-running.
Dog-One
Here's some scope shots of my 34.45 meter grenade coil.  I used three methods (all using a pulse generator) to confirm the frequency response:  impulse ring, max amplitude and FFT.  All three methods pretty much confirm ~ 5.8 MHz.
So with a known length, confirmed frequency response and the knowledge of the speed-of-light, we should be able to calculate a "typical" velocity factor relationship.
Unless the wire length really has no bearing on the frequency response.  I'm still on the fence with this one until T-1000 can find me something more concrete.
Using this online calculator:  http://www.1728.org/freqwave.htm
I get  8.7022 MHz.
So if we divide 5.8 by 8.7, we get a velocity factor of 0.66 which is pretty typical for coax transmission line.
If this is all correct than I would assume you can take your wire length for your grenade coil, input it to the above calculator, then multiply the result by 2/3rds to estimate your resonant frequency.
BTW, someone will probably have to quote this for Nick since I'm getting the feeling he has me on an ignore list.
Hoppy
Quote from: NickZ on September 30, 2015, 09:24:17 AM
  As I had mentioned, Ruslan is continually changing his device, and schematics. This can make it a bitch to try to keep up with.
  The 0.1uf 1000v capacitor is part of the two needed WIMA tuning caps. This one is for the 168 turns coil circuit, placed in parallel, and the 0.47uf 700 to 2000v tuning cap is placed in series at the 3 turns/inductor circuit.
Please give a link to where you saw this 0.1uF cap across the grenade coil on Ruslan's circuit diagram or build.
