0 Members and 295 Guests are viewing this topic.
Hoppy
Quote from: T-1000 on September 30, 2015, 03:20:59 PM
The insulation breakage occur not always in normal operating conditions as there power surges happen. Some spectacular arcing happen when there are wires being disconnected such as in https://www.youtube.com/watch?v=MAlyEMQxTN0 or some inital short path introduced as in https://www.youtube.com/watch?v=-yBTHrXEK4U and also the wire can be physically kicked by higher current on the power on moments. We all know about BEMF but when it happens to make plasma from air, the things are different as there are oscillations making high frequency spectrum in there.
In the case of arcing when wires are disconnected, spectacular events are normally associated by conductors carrying high inductive currents, causing local heating at the point of disconnection. Observation of this type of event in Tesla's time and the damage that it can cause, without today's understanding of this effect was clearly very frightening and prompted much speculation. Much of the present belief in 'free energy' was borne out of the wonderment of these then little understood events, which years later took on an almost magical explanation by some of those who revere Tesla.
T-1000
Quote from: Hoppy on September 30, 2015, 04:08:00 PM
As I mentioned before about the "secret hidden in plain sight" - for sustaining the 10+ meters wide arcs in the air the 300-500kV alone won't be enough as it is in the power line. And when the power surge happen from stray frequencies inside of low frequency signal also the conditions are worth exploring for producing such events in useful way.
Will not stress on this much as the blind cannot be forced to see things... :)
Hoppy
Quote from: T-1000 on September 30, 2015, 04:31:05 PM
If you continue talking in riddles, then I will remain blind.  ;)
In the first of those two videos, the arc is happening when a formerly closed set of contacts, carrying the line current, is opened. The arc forms across a very small gap at first and sustains as the gap opens fully. When the air is ionized it forms a _low resistance_ channel which then allows the energy stored in the inductance of a very long length of wire (the transmission line) to discharge across the gap. It doesn't take anything like the great voltages cited by T-1000 to arc across a low-resistance channel of ionized air.
In the second video, some utter idiot is short-circuiting the transmission line with a length of wire, which instantly vaporizes from the high current. This again produces a _low resistance_ channel of ionized air (and wire material!). The energy which is so spectacularly released is once again the stored energy in the inductance of the long lengths of wire in the transmission line, plus whatever is being continually supplied by the power source, before the line's vacuum breakers (back at the substation) have a chance to shut off the current.
A similar thing happens in my Jacob's Ladder demonstrations, where the actual _voltage_ is "only" enough to jump across a nonionized gap of about 8 or 9 mm, but once the low resistance ionized air channel is formed, the arc can maintain itself at much greater separations of 10-15 cm or more, until the hot ionized air channel is broken up by convection.
http://www.youtube.com/watch?v=4XRwlNCF1PU
Dog-One
