0 Members and 246 Guests are viewing this topic.
Jeg
Quote from: TinselKoala on October 04, 2015, 06:03:58 PM
For those of you with DSOs, you should be able to try another method, and grab the result with the Single-Shot sweep mode of your scopes.
Tinsel, is any other setting that i need to adjust before doing this?
Yesterday when measuring my grenade, i noticed that sometimes the signal in Rigol's monitor was going up and down  between some 30mV and 138mV. I thought that a parasitic signal influenced my readings and that was just the coil detecting it. But at the end occurred that the switch located in Rigol's Probe, was changing mode between X1 and X10 arbitrarily. (Bad or loose internal switch contact). Very weak point of the probe. I could have destroy my probe or even Rigol's input if this transition was taking place at the moment of measuring a voltage of 250V :(
Hoppy
Quote from: T-1000 on October 05, 2015, 04:06:34 AM
What is question, to be exact? If you refer to circuit versions, I can't tell which is latest.
I'll re-phrase my question: Can you tell us from your knowledge and understanding of what Ruslan is saying in his various videos, whether he is currently using the winding configuration for the grenade coil that you posted (10662) in reply to Jeg, where you say: "Each leg windings are opposite to previous leg with 2 layers each."? This is both contrary to the original winding instructions from Ruslan and the recent post (10670) from John.K1 who says that Ruslan has now reverted to a uni directional wind from start to finish. If you do not know the current winding configuration used by Ruslan, then please tell us how you know that the configuration should be as you stated in post 10662.
T-1000
Quote from: Hoppy on October 05, 2015, 05:57:12 AM
The best answer is from Ruslan himself in teamspeak conference notes - http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg420098/#msg420098
"2) The Grenade coil - It is receiver wound on tube of 50mm diameter with length of ~21cm length, full winding on it for layer forward and continue with second layer to same direction, then divide its length by 2, put the same cable from the end of 2nd layer until middle and wind into opposite direction direction until end then continue with second layer to same direction, then again divide by 2 and put the wire until middle from end of previous coil and wind into opposite again until end (the last half is in same direction as longest bottom) then continue layer on same direction. Then put wire across top coil and put inside of tube then make exiting under begining of coil."
I generally reminded that on post #10662 and if you are still skeptical, you can watch all Ruslan demos videos and try to find moments where winding sections are clearly seen.
Jeg
Hi Hoppy
I am not answering for T1000 as I am also interested in where T1000 have read this info. But, it is fair to say that the only thing that will change by the different coil setups is the choice of the right harmonic. In some cases if you like to tune in higher frequencies, T1000's suggestion is more appropriate as it will give a lower inductance and so you have the ability to tune to a higher frequency than with a grenade wounded as suggested by John.K for example. It is a matter of personal taste and design.
Hoppy
Quote from: T-1000 on October 05, 2015, 07:02:01 AM
Ok. Thanks for the clarification that your information is purely based on the teamspeak conference notes. Its unfortunate that his teach-in diagrams (see earlier posts) do not seem to tie-up with this conference note, neither do the observations that I have made on some of Ruslan's video's that show good close-up views of the grenade coil. Anyway, it looks like various configurations will need to be tried, as he may well have made changes to the configuration since the conference as suggested by John.K1.
