0 Members and 276 Guests are viewing this topic.
itsu
Quote from: John.K1 on October 08, 2015, 07:03:57 AM
Itsu- try to extract it by using free 7-zip program.  It worked for me. It still say Unexpected end of the file but you can see filled spreadsheet. WinRar didn't work for me to extract it.
Hi John,
no, also with 7-zip it says the file is empty  (its only 8KB).
Itsu
T-1000
Quote from: itsu on October 08, 2015, 09:58:58 AM
my pico-pulser only outputs a 740ps pulse of 2/3V, which will not light up a CFL, so i don't think it will light up a CFL when further down the
My understanding was you were pulsing MOSFET gate on Tesla coil driver side. It need to pass through MOSFET and trigger pulse on Tesla coil primary from +130-150V source so the voltage will be amplified to kV range where CFL will come handy as indicator.
itsu
Quote from: T-1000 on October 08, 2015, 10:05:57 AM
Aha, ok so we did misunderstand each other.
No i have a stand alone pico-pulser which i use to pulse a coax (transmission line) to measure its length, velocity factor and impedance if unknown.
I tried that on the grenade, but it does not act like a transmission line as i do not see any reflected pulse coming back from the end of the grenade.
Regards Itsu
itsu
Quote from: Hoppy on October 04, 2015, 06:34:50 AM
Hi Tomtech,
I cannot comment on the PLL circuitry because I have not built and experimented with this. However, my experience using the push-pull driving the yoke is that the power rails are 'spiked' leading to the linear voltage regulators serving the oscillator and other parts of the device being stressed and overheated. The UR4007 protection diodes shown on the ALLEGGA circuit are IMO inadequate and a 'clamp' winding as detailed by Verpies is ideally needed to clean-up the yoke output waveform.
Hoppy,
concerning the above quote in bold, are you refering to the below snubber details (see picture)?
Any comment on this snubber setup, is it adequate?
Its taken from this diagram here:  http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg461537/#msg461537
Regards Itsu
T-1000
Quote from: itsu on October 08, 2015, 10:14:03 AM
WIth low voltages it is unknown where signal will stop as the grenade coil is far from perfect transmission line and the losses probably are too great for this instrument. My suggestion would be to fall back on old primitive ways of measurements and pass high voltage from Tesla coil for a signal over top load series capacitance to grenade coil then see how far the signal propagates.
P.S> the YT link https://www.youtube.com/watch?v=Qz1-RIcj1HY from Hoppy is valid at this point because we want to tune maximum transmission over coiled wire to the end.
