0 Members and 562 Guests are viewing this topic.
Hoppy
Quote from: itsu on October 08, 2015, 10:34:00 AM
Hoppy,
concerning the above quote in bold, are you refering to the below snubber details (see picture)?
Any comment on this snubber setup, is it adequate?
Its taken from this diagram here:  http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg461537/#msg461537
Regards Itsu
Hi Itsu,
Yes, that is the diagram. I do not consider this snubber as adequate, whilst using linear voltage regulators running other elements of the circuit direct from the main power rail. Ideally, the control circuitry should be supplied from a separate supply with a common circuit grounding point with the main power supply. However, if Verpies clamping arrangement is used, then I have found that there is reduced stress from spiking to the voltage regulators.
Hoppy
Dog-One
Quote from: itsu on October 08, 2015, 10:00:05 AM
no, also with 7-zip it says the file is empty  (its only 8KB).
Redo:
I saved it in a couple different formats.  Hopefully one of them is readable by everyone.
Quote from: Dog-One on October 08, 2015, 03:42:38 PM
Redo:
This one works properly. I can unzip it and read all four of the different formats inside.
(The forum has been known to corrupt .zip files, so maybe that's what happened to your first file.)
Dog-One
Quote from: TinselKoala on October 08, 2015, 05:15:41 PM
Cool.
The goal of this is get the physical dimensions and estimated resonant frequencies of each coil layer in a format where I can attempt to visualize how possibly the standing waves move, what the impedance mismatch between layers looks like and how much reflection there may be.
I find it very interesting the total length resonant frequency is so similar to the paired bandwidth frequency (difference between paired layers), all in the 5MHz range.  I'm still trying to find a pattern to the harmonics for each layer.  It surely looks like there is one, I just can't put a ratio to it yet.
If I get lucky, it may become apparent exactly what this grenade coil is attempting to produce; then it's just a matter of calculating the exact physical dimensions for optimal performance.  Going to take a lot of "what if" analysis.  My hunch right now is the paired layers create a bandwidth tunnel forcing the frequencies to stay within that range.  So I'm guessing the center frequency for each paired layer must end up to be some harmonic of the total resonant frequency.  What the harmonic numbers turn out to be could be very important to understanding its operation.  Right now I'm seeing possibly 4, 6 & 9.
AlienGrey
has any one seen this vid,    https://www.youtube.com/watch?v=yPvQOPNYiS4
it originally had another video showing how to make it, it has 80 turns primary  and the secondary is 5 +5, it obviously amplifies energy, think is has any one got the second video they can post ?
Many thanks Alien
