0 Members and 655 Guests are viewing this topic.
NickZ
  Well, the "ol dog", me, just finishes rewinding the Kacher secondary, to bring it down to about 1.85Mhz, or so. And I also rewound my grenade's inductor coil, as it was still at 12, 12, turns, and now has the 24t, 24t turns to have the recommended 48 turns, instead of the previous 24t.
  The Kacher signal from the antenna can now light a microwave 20w bulb, at the open ends of the 48  turns inductor coil, plus a 10 watt bulb on the open ends of the grenade output coil, at the same time. But, dimly, as the kacher spark streamer is only 1-2mm long, and still no stinging felt from the HV. Up to now I have not been able to light any incandescent bulbs from the Kachers' output, at all.
  Tomorrow I'll connect the grenade coils back up to the yoke, and do some scope shots and readings, to see what frequencies are running now, and possibly make a video.
AlienGrey
Quote from: NickZ on October 09, 2015, 08:15:01 PM
  The Kacher signal from the antenna can now light a microwave 20w bulb, at the open ends of the 48  turns conductor coil, plus a 10 watt bulb on the open ends of the grenade output coil, at the same time. But, dimly, as the kacher spark streamer is only 1-2mm long, and still no stinging felt from the HV. Up to now I have not been able to light any incandescent bulbs from the Kachers' output, at all.
Nick are you still using that twin FET self oscillating circuit to drive your grenade coil via the old scan coils device, I did some tests on that type of circuit and it is SO BLOODY UNSTABLE to the slightest voltage change it is so unbelievable, How can you possibly expect to the device as a whole get it to work ? You can't.
Hoppy
Quote from: T-1000 on October 08, 2015, 10:41:21 AM
P.S> the YT link https://www.youtube.com/watch?v=Qz1-RIcj1HY from Hoppy is valid at this point because we want to tune maximum transmission over coiled wire to the end.
According to the comments from the producer accompanying that video, the input was around 600W with output at around 60W!, thereby needing the oil baths for cooling the ignition transformers. Not the way to go for the transmission of electricity!!
T-1000
Quote from: Hoppy on October 10, 2015, 05:09:58 AM
I was about not power measurements for input and output. The single wire transmission having coils in the end was the point.
Hoppy
Quote from: T-1000 on October 10, 2015, 08:29:21 AM
I fully appreciate you were only making a point about the transmission coils but I felt it worth also pointing out that this is a very inefficient method of power transmission.
