0 Members and 557 Guests are viewing this topic.
Hoppy
Quote from: NickZ on October 10, 2015, 10:16:46 AM
   Alien Grey:
  You mentioned: "Nick are you still using that twin FET self oscillating circuit to drive your grenade coil via the old scan coils device"
  I don't know what circuit that you think that I'm using, but, if you have a better suggestion, please show it working. As up to now no one here has anything that works, and self runs.
  If you watch the Ruslan videos, you can see how each additional bulb added to the other bulbs radically changes and drops the output of the other bulbs. Do you think that the voltage and frequency are not changing?  He can't even light all 4 big bulbs at once, and needs to unscrew one of them to be able to start the device. Why do you think that is???
Good point Nick. So lets drop all the bull.... about the need for a phase-locked or stable frequency just to get it up and working. That is, if we are to believe that that Ruslan really is demonstrating a self-running device(s).
NickZ
  Hoppy:
  I don't know about dropping anything... as it may be all essential for the current versions.
But,  I doubt that neither Oleg, Ruslan or Akula started with such a complicated device.
   Itsu believes that there is nothing complicated about it, and that it can be made to work in a similar fashion using standard electronic practices and circuits, or by using the same components, and lay-outs.  And, I think that he's right.  So, one way would be to make the same boards as Oleg has made, with the exact same components if possible, and see what happens.
OR... each of us can go our merry ways, like we're doing now. But, with each device or drivers that we come up with being different, we can't really compare notes.
    "Variety is the spice of life."
    OR, is it?
Hoppy
Nick,
Breadboard it like Itsu to begin with.
NickZ
  Hoppy: Yes, but will it work?  The only way to know is to make it.
  I'm glad to see Itsu giving it a go at it.  Looks like his new Kacher circuit is working fine, and not heating up. I hope that his new push-pull breadboarding effects pan out, as well.
   Itsu: Before I connect up my grenade's coils back to the yoke/Mazilli crt. Should I test the running frequencies again on the SG to see what the my newly rewound 48 turns inductor coil mounted on top of the 168 turns output coil reads on the SG/scope readings. Yes? Or wait until all the grenade coils and Kacher/antenna are mounted, then test the frequencies?
itsu
Quote from: NickZ on October 10, 2015, 12:12:49 PM
Hi Nick,
you can do both, then you can get some idea the way things are changing when dressing up the grenade.
If its to much hassle, i would do it when completely installed with Kacher/antenna.
Regards Itsu
