0 Members and 119 Guests are viewing this topic.
John.K1
Just thinking how lucky was Ruslan that he got Oleg's board , otherwise it wouldn't be working:)  Also wonder if Akula got some too :D  Nick, even Ruslan says in his videos - "do it from what ever you want. Actually he used the words like (give a shit what you make it from, make it from kacher (it is harder to control) or SG ,it doesn't matter , as long you follow the main principle and get synchro it will work ."
NickZ
  Itsu:
  I connected the SG to the 48 turns inductor coil, and the scope probes on the 168t output coil. The best cleanest signal is at the very top of the 2Mhz, and could probably go a bit higher if it could, but the SG is maxed out at 2Mhz.
There is another frequency that makes the signal at the grenade's output go even higher, but it's not a clean sine wave.  So, the previous 12, 12 turns coil resonated at 1.85Mhz, and the new 48 turns coil likes 2Mhz, or higher. The new 48 turns inductor can also light a 20w 220v microwave bulb, but dimly, not fully bright from the Kacher signal, which has also been changed and rewound again, but I have not tested the frequency yet.  The earth ground can make a big difference, as well to the bulb brightness and frequency/voltage levels. Without the earth ground the bulb brightness is weaker.
  I'll connect yoke/Mazilli back up now, and take some more readings.
itsu
Nick,
the 48 turns inductor coil has a resonance frequency of its own and will interfere when measuring the 168 turns grenade.
Use the 1 / 2 turn method or the Tinsel pulse method.
You need to use and stick by one method else you have too many parameters changing all the time.
Note down the found values for later reference.
Regards Itsu
AlienGrey
Nick Quote
I don't know what circuit that you think that I'm using, but, if you have a better suggestion, please show it working. As up to now no one here has anything that works, and self runs.
  If you watch the Ruslan videos, you can see how each additional bulb added to the other bulbs radically changes and drops the output of the other bulbs. Do you think that the voltage and frequency are not changing?  He can't even light all 4 big bulbs at once, and needs to unscrew one of them to be able to start the device. Why do you think that is???
Aliens reply
I think you call it the Mazili or something like that, it does work but as resonance is approached and it's loaded with a bulb ect the frequency starts to drift as it's unstable, it's needs some sort of stable driver circuit, as for self starting, get it running first in resonance then expand. Watch the video on Wesley's channel again ( https://www.youtube.com/watch?v=OhJYDTGCoLs ) and pay attention to what he is saying, Itsu has a video on the same thing do not follow that it's got errors in it.
NickZ
   Itsu:
   I should have tested the grenade output coil self resonance frequency, before I rewound the inductor to 48 turns and placed it on  top of it. But, I didn't think of it when I had the chance.
Now the 1 turns test coil connected from the SG, has to be placed on top of the inductor coil, which can influence the resonance readings of the output coil.
   So, in any case I'll see what the grenade reads with the new inductor in place.
  EDIT: Here's the scope shot of the new grenade readings. This is using a one turn coil over the inductor coil to test the grenade's output coil self resonance frequency.  I get 1.15 divitions, at .5us= 0.575us, for 1.74Mhz. Correct?
