0 Members and 588 Guests are viewing this topic.
Hoppy
Quote from: itsu on October 13, 2015, 03:17:45 PM
(or are there different ERL-35 layouts??)
Regards Itsu
Itsu,
Yes, the ERL-35 is the core type and there will be various winding configurations used for PC PSU's. The particular winding configuration shown in the spec you posted, clearly does not allow the transformer to be used in a step-up config. I found a transformer from an old PC PSU (with codings TF-463 & LS-130B-1) that measures out as suitable for step-up with a ratio of 1:5.
a.king21
I am wondering if this is the missing part of the Kapanadze puzzle.
Any constructive comments??
http://crystalradioinitiative.com/
I believe the FE diagram is here http://www.gestaltreality.com/energy-synthesis/eric-dollard/additional-posts-by-e-p-dollard-2012/
itsu
Quote from: Hoppy on October 13, 2015, 05:37:32 PM
Itsu,
Hoppy,
Ok, good to know,
i will check my transformers for a useable step-up with a ratio of 1:5
Regards Itsu
Hoppy
Quote from: itsu on October 14, 2015, 05:00:12 AM
Hoppy,
Ok, good to know,
Regards Itsu
Itsu,
Thinking about this further, as this is reasonably low powered forward converter, you should be able to drive the primary unipolar, so not needing a centre tap winding. So any main PC SM step-down transformer working reversed should work to give the required 300V DC output @ around 0.2A, when rectified and smoothed. I'll have to try this out myself.
Hoppy
Itsu,
I setup my transformer with a PWM drive running at 31KHz with a 24V supply. The output was rectified and smoothed with a 33uF cap. The most efficient running with best 50% duty waveform produced a DC voltage of 98V across a 1K load resistor (200V pk-pk across transformer output). The supply current was 0.22A. It would appear that the turns ratio of 1:5 needs to be increased, so its quite possible that the transformer in the ALLEGGA circuit was custom wound.
Hoppy
