0 Members and 109 Guests are viewing this topic.
Tomtech29
- I asked earlier how does it affect shift (I had the impression that the delay)It will have an impact on current performance but consequently one from the transistor works harder
if this is as I understand .
itsu
Tomtech29,
ok, i added some extra bulbs, in steps of 100W, so first the 40W,  then 140W, then 240W etc.
The resonance frequency goes up in steps of about 1KHz but the input current drops significally after adding the first 100W bulb.
Hope this is what you wanted to know.
Video here:  https://www.youtube.com/watch?v=mKMz4omOTPI&feature=youtu.be
Regards Itsu
itsu
I added the new kacher driver to the mix to get a picture of the timing of it all.
Below screenshot shows the kacher being fired (purple trace), the inductor voltage (yellow) and inductor current (green)
As before, the grenade was only loaded with a 40W bulb
This picture is similar as the earlier mentioned diagram in post #10839  here:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg463092/#msg463092
So we see the kacher is fired at max voltage across the inductor, and i have the feeling it needs to switch on at the peak of the current (green trace).
Not sure how to do that.
Regards Itsu
itsu
Quote from: Tomtech29 on October 18, 2015, 02:54:22 PM
Tomtech29,
not sure what you mean here, those signals are no transistor signals, they are the signals on pins 3 and 4 of the PLL chip (4046).
I have set them with the R8 pot to be switching at the same time (compensate for the delay of the feedback signal as i understand it).
See this post:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg462370/#msg462370
Regards Itsu
Tomtech29
:D
:D
so all I agree so much that I tried the light bulb to a maximum power of 200 watts still think about the fact that ie the yellow and blue signal is not of the transistor's gate
and both signals in your push-pull are identical 50/50% without which the  delay timer for gates
Synchronization keeps both signals at the gates equally
-it may seem strange to you but I thought that one channel experience bath set at a different time to the second.
