0 Members and 433 Guests are viewing this topic.
John.K1
Hi there,
Just uploaded the movie with some for me weird effect of Kacher driven Tesla coil and the fluorescent bulb. Maybe you can give me an answer for my question ;)
https://www.youtube.com/watch?v=-FTkUoS7nKo&feature=youtu.be
Hoppy
@all,
Further experimentation using a PC switched-mode transformer for the 130V PSU, has suggested that a simple Mazilli based oscillator can be used quite effectively to drive the transformer and I think a good choice for Nick and performs as well as the push-pull version I built. I have attached a revised schematic of the pin layout and connections needed. The mosfet drains are connected to the transformers original 12V PC winding and uses the thick earth lead as a centre-tap, which should be connected to a 24V supply to power the Mazilli. My transformer is a Hi-Pot type and has the ERL-35C code for the core written on top of the transformer. A photo shot of this transformer type can be seen in Itsu's post 10868. I used 2 x 0.15uF caps in parallel across the Mazilli output and a full wave rectifier bridge with 100uF / 400V electrolytic cap for smoothing. A smaller cap of 47uF would also be fine but make sure it has a voltage rating no less that 400V. The final DC voltage may be over 130V but can be adjusted as explained by Dog-One if necessary.
Tomtech29
Quote from: John.K1 on October 18, 2015, 05:40:11 PM
Hi there,
hi.I do not know if I'm right I can see you're using a permanent magnet at the restriction for what purpose?
besides I see the mistake in the construction of cardiovascular using the resistor and potentiometer circuit base
and you tried to reverse the polarity.
Tomtech29
Itsu remember a snippet of film as Ruslan shows the coil on the table two white wires directed to the bulb from the holder and red capacitor where does another bulb of 100 watts and there is also a recognition of the oscilloscope at the end of the ferrite rod inserted
I can not find him someone could paste it already there is a high goodness coil. The devil knows where is the catch check this>I suppose it is a 160 watt in half but lights could glow would you be interested
John.K1
Hi Tomtech-  This is only basic Kacher I made for experimenting. The one I have for Ruslan's device is more sophisticated with diodes and several wat resistors. Yes you are right, I use a magnet here, and it seems to be working better with it, and also I can use it as an switch or valve if need (just turn the magnet :)  ).
I do not understand what mistake you talking about. Can you please explain in detail?
In any case-  why does bulb lit in right distance only??  I can bring different objects close to the coil (glass tubes, large homemade capacitors etc..)  and they do not have the same killing effect like the fluorescent tube I used. Some question ;)
