Tomtech29
Itsu
I would like to know how many light bulbs you can fire up to Compare
I did some tests and it came to me that resonance must be under full load in my case is 3X100 watts light bulbs (3 Bulbs parallel resistance of 13.5 ohms)
when the coil was open I found out that I have a high peak amplitude of the resonance but power consumption is 9 amps fell when another light bulb plugged up to 5 Amps but found another resonance mode when under full load it turned out that there is no such difference
I suppose that tuning is performed under load
Tomtech29
Blue amplitude capacitor 2x 0.47
Yellow amplitude open coil grenade (power consumption from the power supply is 6.7 Amps)
-and now see if I have a load of 3 x 100 Watt voltage drops to 54 volts the output and power from the power supply is 1.7 Amper less.= 5 Amps
NickZ
  Tomtech:
  My bulbs will brighten up when going from one bulb to three bulbs, but will start to dim when going over three to four or more 100w bulbs. I've partially lit as many as 650w worth of bulbs, but not because of 650w worth of output power.
   Tuning should be done to find the best open coil resonant point for the grenade, first, and then tune to the Kacher system to operate at that point, but, also try to see if there is also a better Kacher resonant point, once your 3 bulbs are connected, along with the recommended 37.5 meter earth ground line.
  There may be nothing magical about the 15Khz induction coil crt, or the 1.5Mhz.,  for the Kacher, 1:100 ratios, or the other rations. And any system may operate a different frequency, once all the bulbs are connected up as a load.
   So, we need to find the best operating frequency for all three circuits, Kacher, grenade, inductor, and then try to further sync them all together.
     Easier said than done...   As it's not just a matter of turning some knobs, as some guys may think.
  To compare notes: My grenade's best resonant point (OPEN coil) was at 1.85Mhz.  But, my best running lumin levels are between 1.42Mzh, to 1.53Mhz, or so.
  Your LED bulb test method ran best on my grenade's output coil at 1.53Mhz.  Ferrite placed in the Kacher can further adjust the frequency.
   But, there may also be a good reason that Akula/Ruslan are ONLY using the bigger 500w to 1000w bulbs on their systems.
  I'm still tuning away... and getting everything connected back together.
Tomtech29
Quote from: NickZ on October 19, 2015, 09:27:24 AM
  Tomtech:
  I would be more concerned about why your bulbs are barely lit. You should be getting much higher lumin levels.
Hi NickZ
we are talking here only about the exit grenade driven only 3 windings on a ferrite core with no windings 28 and without Kacher see how he hooked Itsu
and we use light bulbs to 230 Volt with a power of 100 Watt.
What about you how this set?
-Using the Drive 24 Volt see what has brightness Ruslan under 160 watts. I used the maximum of 300 watts to compare, and now you can see what's brightness 30%
I am looking for references to the efficiency of the coil sea can be seen from different design coils can be the difference and as well as in your case, the drive system to Youke
AlienGrey
Quote from: TinselKoala on October 19, 2015, 02:43:02 AM
Nice work John. I put a comment on your video giving my impressions. Cheers-- keep up the good work.
Yeah the tube has mercury in it for starters it's a load loop and wire is so thin, is he tuning it to a long wave station ;) but seriously he needs some capacitance on the top like a ball covered in foil or old dog food tin,and the tube, is loading effect on the Tesla coil at a guess.
try re winding it with thicker wire.
