0 Members and 596 Guests are viewing this topic.
Hoppy
Quote from: itsu on October 18, 2015, 03:00:34 PM
Tomtech29,
ok, i added some extra bulbs, in steps of 100W, so first the 40W,  then 140W, then 240W etc.
The resonance frequency goes up in steps of about 1KHz but the input current drops significally after adding the first 100W bulb.
Hope this is what you wanted to know.
Video here:  https://www.youtube.com/watch?v=mKMz4omOTPI&feature=youtu.be
Regards Itsu
Itsu,
Was this demonstration with or without the 28-wire yoke winding connected? I assume it was as Tomtech requested, just with the induction coil driven.
Hoppy
John.K1
Quote from: AlienGrey on October 19, 2015, 10:09:46 AM
Yeah the tube has mercury in it for starters it's a load loop and wire is so thin, is he tuning it to a long wave station ;) but seriously he needs some capacitance on the top like a ball covered in foil or old dog food tin,and the tube, is loading effect on the Tesla coil at a guess.
try re winding it with thicker wire.
Hi Alien. Yep , that Kacher  was made for different coil, the coil made of thicker wire ( the wire from data cables, Insulated 0.5mm or so). The coil was tuned to have 2.78 MHz  ( Around 150 turns of wire or so) , but Kacher didn't work on that one- even with 30V supply. I couldn't get resonance. So I tested it on this older longer coil you see in the movie. Just needed to prove Kacher works. Now the question is how to get Kacher to work on less turnes. I need that 2.78 MHz.
Tomtech29
Quote from: NickZ on October 19, 2015, 09:27:24 AM
  Tomtech:
  I would be more concerned about why your bulbs are barely lit, as you should be getting higher lumin levels, at 5-6 amps.
My bulbs will brighten up when going from one bulb to three bulbs, but will start to dim when going over three of four 100w bulbs. I've partially lit as many as 650w worth of bulbs, (or more), but not because of 650w worth of output power.
   Tuning should be done to find the best open coil resonant point for the grenade, first, and then tune to the Kacher system to operate at that point, but, also try to see if there is also a better resonant point, once your 3 bulbs are connected. There may be nothing magical about the 15Khz induction coil crt, or the 1.5Mhz.,  for the Kacher, 1:100 ratios, or the other rations.
    Your system may operate a different frequency, once the bulbs (3 100w bulbs) are connected up as a load. So we need to find the best operating frequency, for all three circuits, Kacher grenade, inductor, and then try to further sync them all together.
Easier said than done...
As it not just a matter of turning some knobs, as some guys may think.
  To compare notes: My grenade's best resonant point (OPEN coil) was at 1.85Mhz.  But, my best running lumin levels are between 1.42Mzh, to 1.53Mhz, or so.
  Your LED bulb test method ran best on my grenade's output coil at 1.53Mhz.  Ferrite placed in the Kacher can further adjust the frequency.
   Keep the same 3 bulb load, as each additional bulb can change the brightness of the all bulbs, even if the frequency is locked.
But, there is also a good reason that Akula/Ruslan are ONLY using the bigger 500w to 1000w bulbs on the Akula/Ruslan systems.
I have the impression that you have not seen this film, see what happens when Ruslan joined together at both ends of the coil grenade:
https://www.youtube.com/watch?v=9bE_9cFX5bI
if he could fire 650 Watt output of the grenade that would be visible under short circuit arc (stronger sparks)
I am faithless show me such a result as you say!
Tomtech29
Quote from: T-1000 on October 19, 2015, 08:31:09 AM
There are some questions for your case:
Why the amplitude from LC series resonance goes to very low level as soon as you load up 140W?
Is it trying to draw more amps from PS then have not enough from 120W and then is dropping oscillation?
Is the yoke core over satturated?
-I do not know what is the limit load for Ruslan but we see that the 160 Watt amplitude decreases
  like guessing and see what remains to be seen under a magnifying glass (experience bath to check Pusch-pull performance of the starting 28 at these bulbs of 100 watts and so on.)
AlienGrey
Quote from: John.K1 on October 19, 2015, 12:17:23 PM
If you look at old Ruslan vids the coil is under yellow tape, if it is 1/4 wave of granade coil that would make it 8 mhz with short coil to match, 8mhz would be around that number of turns, or 6mhz for the other version, you need a scope to see the wave forms.
