0 Members and 144 Guests are viewing this topic.
itsu
Quote from: starcruiser on October 19, 2015, 06:57:01 PM
I would suggest you invert the trigger signal to the Kacher circuit, trigger it on the negative peak of the voltage sine-wave and delay it a bit using the RC circuit to line it up with the positive peak of the Current sine-wave.
Thanks starcruiser,
i tried that,  but flipping the switch did not change the signals, and turning the R5 and R9 pots does not have much influence, it certainly did not move the kacher signal compared to the inductor voltage/current signals.
Only action i can see is that the pulse on the (inverted) output of the ucc27321 is getting wider or narrower
It makes the PLL / resonance unstable as it makes the 40W bulb go off / become brighter at certain points of the R9 pot.
Anyway,  i will try some more variations with the switch and pots,  thanks.
Regards Itsu
itsu
Quote from: NickZ on October 19, 2015, 10:08:17 PM
  Itsu:
  With my new set up I find that the yoke core and/or it windings are getting warm, but not too hot.  Never happened before. This is with NO magnetite magnet inside of the core. But, my inductor coil does not get warm at all.
Nick,
we cannot compare our circuits as you have your mazilli while i have the PLL to control the inductor resonance circuit.
Are you sure the mazilli and the inductor/wima caps are resonating on the same frequency?
I guess with your 0.47uF wima cap, your inductor will resonate around 27Khz, it that also what you measure on the mazilli?
Regards Itsu
itsu
Quote from: Hoppy on October 20, 2015, 03:39:02 AM
@ all,
I have noticed a small difference (see below) between the Allegga circuit and the Ruslan hand drawn schematic shown towards the end of this video.
Hoppy,   good spotted, but also the second C** is missing (at the output caps) and we see a VD1 diode too which is not in the Allegga diagram,  hmmm.....
Thanks,  regards Itsu
AlienGrey
That's interesting D1 and it's cap in a coil to coil thing, what will half wave DC do (over heat the coil ?) if you want an RC charge effect use a resister.
AlienGrey
Has any one got a scope shot of a tuned katcher grenade wave forms on the same scope shot, so we can see whats going on ?
Your cooperation would be most appreciated and benafical to all concerned.
cheers Alien
