NickZ
    Hoppy:
   Even the simple approach is still a very complicated mix to contend with, as I'm seeing.
   I actually had slightly better results, before I started this last round of tuning rewinding, and adjusting the circuits.  Now my earth ground line does nothing, nor do I notice the slightest improvement in the bulbs output and brightness. Which is indicating that what I did was not right.  So, "by chance" seam to be the better approach so far, as the SG or the scope have not helped to find the way, as yet.
Hoppy
Quote from: NickZ on October 21, 2015, 09:53:22 AM
    Hoppy:
Maybe working on intuition, with a good dose of luck will prove to be the quickest route to success. After all Kapanadze probably trod this route.  :-\
Hoppy
Quote from: Tomtech29 on October 21, 2015, 09:40:49 AM
most of these schemes shows such entry but to get rid of the high voltage is close to ground if you want someone other schemes is different?
Sorry Tomtech but that sentence makes no sense.
Tomtech29
Quote from: Hoppy on October 21, 2015, 10:00:54 AM
I think the location of this small transformer on the wire that is the ground and three turnovers  which is grounded wire has a lower current I'd try to check on both ends of the inductor where he will be better if the high voltage is not pierced PLL. 2.6KV Vpp is definitely very high.
itsu
I ordered and received one of these modules:
http://www.ebay.com/itm/TL494-KA7500-DC-9V-25V-Driver-Board-DC-DC-Converter-Inverter-Boost-Module-PWM-/181449170972?hash=item2a3f36a01c:g:zKQAAOSwu4BVpJjQ
as discussed earlier here:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg461714/#msg461714
It runs at 32Khz, but after removing R6 (18K) and installing a 100K potmeter instead, it now has a range of 6KHz to 80KHz.
The installed potmeter on this board has no influence on either the frequency nor the duty cycle / pulse width.
I connected this module to my MOSFET drivers (ucc37322) driving the MOSFETs (IRFP260) at a frequency of 15.3Khz which is the resonance frequency of my
inductor coil and it was able to light up a 100W bulb on the grenade coil.
The video shows the tuning of this resonance which is very sharp (± 300KHz).
Perhaps a usefull module.
Video here:  https://www.youtube.com/watch?v=g0Xr-gmFjFY&feature=youtu.be
Attached the via Email received diagram of this module (the component id's are not the same as on the board)
Regards Itsu
