0 Members and 296 Guests are viewing this topic.
itsu
Quote from: verpies on October 21, 2015, 05:35:09 PM
I admit,  I have not been following this struggle and I do not know exactly what circuit you are working on.
From my memory I remember that this contraption consists of 3 components: the Yoke, Grenade and "Kacher".  What is driving what?  What is the source of the feedback signal?  Is there a block diagram?
I really don't have the time to decipher these haphazard Russian schematics that don't follow the basic diagramming conventions.
This is important, if I am to help because LC circuits (or ¼ wave resonance) can be driven at limited phase ranges only and if the PLL is driving the Grenade then it can do so only at certain phases and it is possible that the same PLL cannot drive the "Kacher" in synch with the current waveform at the same time, if the LC oscillation (or ¼ wave resonance) is to be sustained.
P.S.
The DG4102 can do everything that the TL494 can...and with a phase detector it can replace the CD4046, too.
Verpies,
i tried to make up a block diagram, i think its something like the first diagram below.
The feedback detail can be seen on the second diagram lower left corner
As i have heavy current (75A pp) flowing (reactive) in this inductor the 50 turns secondary of the current xformer picks up lots of power.
But more important, it seems to peak on the voltage and not on the current which it suppost to do as a "current" Xformer and as can be
seen in the second diagram (guess J max means I max = current max)
Instead the screenshot below of my situation shows that the kacher fires at U max (yellow = voltage across the inductor/bifilar, green the current through the inductor/bifilar)
I tried severall current Xformers, switched to the other PLL driver (180°) signal with the switch and adjusted the severall pots to no avail.
By the way,  the TL494 board is not for me to use, just some info for other to use it if needed.
Regards Itsu
Hoppy
Quote from: T-1000 on October 22, 2015, 05:10:21 AM
The power amplification achievement is #1, the self-loop is #2. One step at the time ;)
I was just closing the loop for Verpies.  ;)
Jeg
Quote from: itsu on October 22, 2015, 07:37:24 AM
Hi Itsu. You really made a good work with sync. I 'd like to ask where do you measure this HF imposed voltage? Where do you sense this current waveform? At Grenade's side?
itsu
Hi Jeg,
the purple kacher signal (HF) i pickup with the probe hanging 5cm above the antenna.
The current (green trace) i measure with my P6302 current probe at the inductor/bifilar coil, see drawing.
The voltage (yellow trace) i measure also at the inductor/bifilar coil, but across it, see also the drawing.
By the way, this current xformer as shown here (between the cap C2 and the inductor) is not the position i have it and it is not the position it is drawn in the Allegga drawing.
There it is put between the 3-turn coil and the C2 cap, and there is it in my setup!!
Regards Itsu
itsu
Quote from: Tomtech29 on October 22, 2015, 06:20:30 AM
I have a great favor to you Itsu
-if you had some time and tried to make some arrangement for the TL494 using a 3 pin to comparator (you had any ideas what would have helped us)
watch this movie because I've seen how he did it!
3:40
https://www.youtube.com/watch?v=zbfsdamSbXw
Thanks ,Itsu.
It would be my pleasure to do you a favor if possible, but i have no idea what you are asking from me here, please redefine the question,  thanks.
Itsu.
