0 Members and 36 Guests are viewing this topic.
starcruiser
For those who are wondering what I am referring to see graphic attached, the reason for the 4x operating frequency is due to the 90° shift (90 x 4 = 360 one cycle), you will want the cap to reach 1C (charge) within the 90° to trigger the kacher, also the voltage achieved will only be about 63% of what is possible, thus the value of the driving voltage needs to be taken into consideration in order to trigger the gates properly.
Regards,
Carl
starcruiser
Itsu, the 3300pf (3n3), .0033uf cap with the 1k adj resistor shows to be a 300khz+ frequency now this is at a 1C charge rate, the question is will the gate trigger at 63% of the voltage? or will this take a second cycle? this second cycle will reduce the operating frequency to 150khz or a pulse every 2nd cycle of the grenade circuit.
Can you check the logic gates using your scope before and after each stage to determine how it is triggering prior to making any changes?
Regards,
Carl
John.K1
I have a question.
Ruslan's work is based on the Akula's work. Many pages back Nick was posting one of the Akulas movies explaining the principal work of this device.
The funny thing is - Akula consider the inductor (the ferrite bar) between the Tesla secondary and its antenna as a very important element of the device. And why? As he says- it change the sinusoidal wave from the secondary to the wave with sharp front edge .If I good understood  Akula is getting peaks of over 36KV there.  He says this is like a hammer.  Have you got anybody this effect yet?? I am trying to get it myself for two days and still nothing like that. In fact it is hard to believe it can work like that. What is your opinion about it?
Dog-One
Quote from: John.K1 on October 22, 2015, 02:28:01 PM
The ferrite rod is wound in a bucking coil arrangement.  If there is anybody that should understand how it may work, it's Chris Sykes.
My feeling is you wind the ferrite rod slightly out of symmetry; if you have it backwards then you should see the tail end of the output wave getting chopped.  None of this will work though if one of the windings isn't exactly in-tune with the frequency of the Tesla coil.  My feeling is you do the following:
First, wind just enough turns in one direction only so this inductor resonates at the same frequency as the Tesla coil.
If you manage to get this working, then you wind a second coil with one less or one more turn in the opposite direction on the same ferrite rod.
I'm not sure of these two coils which one should be tuned to the Tesla coil, the input side or output side, one of them for sure.  Then, another guess is whether the other one should be higher or lower inductance.  Going to take some trial-n-error watching the scope to figure it out.
NickZ
  Akula is not showing a 36kv spark, or streamer. As his spark on the ferrite rod (second self runner video) is very weak, unlike Ruslan's streamer.
It would be more believe able if Akula showed the mentioned voltage on the scope. Especially as neither Ruslan nor Akula use ferrite (like I do) inside of the Kacher former. And are only using relatively short Tesla secondary coils, so it's hard to imagine 36kv.
  But, the voltage is only part of the story, as both amps and frequency also have to be taken in consideration.  The ferrite rod is what creates the "stinging" effect at the antenna, so it does convert the fluffy HV into a stinging and angry sparking HV streamer.
   Now my Kacher streamer is burning the test wire used to test the streamer. Not to mention what it does to my finger, from the 4 mm burning HV streamer, which smells like BBQ meat, my finger that is.
   What I still don't get, is why Akula or Ruslan don't show the system running at full speed ahead, and then disconnect the Kacher???
                 That's what I want to see...  Would there be any noticeable difference?  From the "boys", and their toys.
