0 Members and 244 Guests are viewing this topic.
Jeg
Quote from: Hoppy on October 22, 2015, 05:43:43 PM
Synched to the grenade current waveform would make more sense to me- I think??
I full agree on this. And that is the why I believe that a hall sensor inside the tube will do the job.
starcruiser
Quote from: itsu on October 23, 2015, 05:35:42 AM
Starcruiser,  aha,  that explains.
Yes i know that your circled cap/pot shifts the pulse but by a small amount, just enough to position it (somewhere) on top of a sign wave, but not enough to put it 90° further or back.
In a skype conversation with Oleg = ALLEGGA = Foreigner i understood that the C5/R8 is used to shift the Kacher pulse on top of the inductors Current peak, but i could have understood wrongly as
it does not make sense.
It more compensates for the feedback delay as mentioned by Lost_bro earlier.
Regards Itsu
Itsu, my thought was to invert the signal pulse using the switch as you have re-worked it and adjust the delay to position the kacher firing at the correct place.
Regards,
Carl
itsu
Hi Starcruiser,
yes i know, i did that in the video of my last answer to you, i flipped the switch, but it switches from the positive top of the voltage to the negative top of the voltage.
The pot (also your R5) only shifts the pulse a little bit, certainly not between the voltage and current tops (90°).
Itsu
NickZ
  While trying some thing out, I came across an interesting signal.  When I connect the earth ground to the 0.47uf capacitor and also to the Kacher's emitter,  I get this signal.  The pulses on both the inductor coil and the Kacher seam to be somehow in sync? And extra gain is noticed at the antenna as well, when this is done. The results are a hot stinging streamer, stronger than normal.
  My antenna's normal output frequency with everything connected up is running 1.2Mhz. And over 3Mhz with no antenna or ferrite rod connected.
  My grenade induction coil/3turns coil at the 0.47uf capacitor reads 29Khz, with the earth ground line connected to this cap.
  Tuning continues...
Hoppy
Quote from: Tomtech29 on October 22, 2015, 08:41:56 PM
The person who tries to explain how to achieve such an impulse:
https://www.youtube.com/watch?v=VGuw3QvoseI
I have not seen this before
Thank you for the clarification and sharing.
That person appears to be using a sensible closed transformer core for this application.
