0 Members and 244 Guests are viewing this topic.
verpies
Quote from: itsu on October 23, 2015, 05:20:30 AM
Ok, so what you are saying is that in this case A) and B) we ALWAYS will have the PLL sync on the VOLTAGE like i see it!
Is that not contradictionary with the fact that a (burdened / unburdened) current xformer can shift 90° (so flipping from voltage to current)?
Yes, it is contradictory.  An AC voltage source can be transfer energy to an LC circuit only when it has a 180° phase component. The PLL always attempts to sync at 0° to the feedback signal.  If the feedback signal is not at 180° then eventually a compromising equilibrium is found, albeit not at the maximum efficiency and the amplitude decreases.
It is important to keep in mind that an AC voltage source cannot transfer energy to an LC circuit at an arbitrary phase and expect to maintain resonance.
Who will win if the AC voltage source attempts to transfer energy to an LC tank at the wrong phase angle is a very interesting question...especially when a PLL controls the AC voltage source.
John.K1
Hi Tomtech. Thanks a lot for the video. That man is very good in explanation. I will watch all his YouTube series.
I have tried the uni-polar impulse and the scope shot below (just a small safe voltage on my short Tesla coil). All as he said ;)   My rise edge has around 100ns. I think it is still a bit too much??  Just wonder if now when w have right pulses the ferite bar on the Tesla plays some role here -either as filter or some mystical edge sharpener?  :)
Regards,
Tomtech29
Quote from: John.K1 on October 23, 2015, 04:08:20 PM
Regards,
I am impressed with your achievements, and I think that if you have so beautifully smooth inflection that the ferrite does not have what you've to do:D
-I suspect that you have planned a significant way ,and clever with you guest still some work ahead of us.
for me there are still many obstacles and language barriers
As we say knowledge is power is the key!
all the best to you all.
P.s
I hope that something will move from place to this topic.
starcruiser
Quote from: itsu on October 23, 2015, 10:05:35 AM
Hi Starcruiser,
yes i know, i did that in the video of my last answer to you, i flipped the switch, but it switches from the positive top of the voltage to the negative top of the voltage.
The pot (also your R5) only shifts the pulse a little bit, certainly not between the voltage and current tops (90°).
Itsu
I understand as you mentioned that prior, the post I made prior was to replace the cap (C1 = 3300pf) with another value to see how this impacts the shift. You thought I was referring to the cap feeding the PLL timing.
Regards,
Carl
NickZ
  Seams like this guy Y pok has obtained the "effect".  And is showing what I had always wanted Akula and Ruslan to show. Only he has only one bulb as the load, and no feed back loop yet.
https://www.youtube.com/watch?v=faCaYvh69Bs
