0 Members and 68 Guests are viewing this topic.
Hoppy
Quote from: NickZ on October 23, 2015, 11:32:15 PM
  Seams like this guy Y pok has obtained the "effect".  And is showing what I had always wanted Akula and Ruslan to show. Only he has only one bulb as the load, and no feed back loop yet.
https://www.youtube.com/watch?v=faCaYvh69Bs
Nick,
That's the effect I achieved on my build but it was not a true power amplification (as referred to as being the necessary effect by T1000) in my case. The increased lamp brightness resulted in increased power draw from the supply. It would have have helped if Y pok showed a measurement of the supply current and voltage with and without the Kacher connected.
itsu
Quote from: verpies on October 24, 2015, 03:42:33 AM
@Itsu
You can pull on pin9 of the CD4046 like in this video to inject a phase offset into the PLL and see for yourself how the AC voltage source transfers energy to the LC circuit at various phases.
Right,   presently it has some fixed RC values attached:
Itsu
John.K1
Hopy, Itsu
I agree, there is nothing special in the last posted movie. I have also many many many  pages back showed light of 20W microwave bulb on the granade coil (one wire setup)  from the Kacher and so far we didn't get more than inefficient  inverter :)  I think LaserSiebers jouleRinger works better so far to compare what we have:)  BUT - it can change if we get the effect based on the unipolar HV pulses - that's what I believe ;)   Also in several movies (this guy, Akula, also partially Ruslan ) they mentioned the word or keywords "plasma" in the wire. "plasma trapped in the magnetic field etc.   Something which should be considered too. In fact it is somehow logical as the HV creates plasma. You can agree or not, I do not border - but this is the fact you can't obey ;)
Anyway. What I am gonna to do today is to get ridoff the Kacher and to use some of the cheepo SG   running Mosfet driver and mosfet at 5th or so harmonic of the frequency of the Tesla coil. SG will make  SQR pulses and I can easily change requency and duty cycle (which controls number of uni-pulses)    .  That's the first stage.
Edit: To clarify it a bit better -We have a Tesla coil which natural frequency is 1/4 o the grenade coil -let's say 1.5MHz - My SG will fire from (1500/5) =  500KHz down on primary .  Than, I will tune the duty cycle (maybe even frequency to next harmonic)  to see some number of unipulses.  The sychronisation will be next step after I will see HV unipolar pulses on my antenna.
Tomtech29
HI.
With the translation of message Ruslan:
"Here incorrect diagram! I posted a video of his new scheme with explanations. There Kacher controlled. Do not worry with these stupid things .... it will not work! You need momentum to the antenna width of 200-500 ns. Besides push-pull must have a PLL, and the momentum to get hump sine and customized to its duration. In addition to the coil sinus nor any other signals and beards should not be."
Guy directly comment on what is wrong and analyzed by the agreement outora see!
and what I see discovering the successive stages and has concepts
I will not convince anyone because it is not a vocation
time passes and uncertainties are shrinking!
Tomtech29
<<it was very much fun to work in a team! and I thus learn from others.
-for me that is what counts and desire to show their work at distances contentment and joy not base it personally try not to be malicious
I would like to to look in this direction was more and more >>
John.k1
badly was you misunderstood my words
1)I would like to see how you're doing
2) do not worry about failure Show what is wrong without <<shame>> no (embarrassment) vice versa in the sense?
3) as you obtain these peaks Karcher-Your current Tesla coil working with such an impulse?
4) Did you use a ferrite rod to tune T.Coil  or if your attempt with adjustable frequency by FG.?
T.Tech
