0 Members and 60 Guests are viewing this topic.
NickZ
   @ T-1000, thanks for the link, I'll check on it.
   @Vortex1:  This may not all work like a regular electric circuit would, if magnetic resonance is the "secret" behind the effect generation, possibly at the expense of the normal known electrical coil induction practices.
   As HV/HF and/or magnetic flux, on the outside of the wires (skin effect) may not burn them out, or work in the same way.
  One of the first TPU circuit devices Steven Marks made could be picked it up, while holding and touching it, yet not get shocked, at the same time showing a very hefty blue/white spark when shorting out the two output wires that read several hundred volts output. Yet, the bulbs and the rest of the circuit were getting very hot.  As are these devices (having possible heat issues, core noise and vibrations), that we are looking into now.
May be related, and may not be...
Vortex1
Quote from: NickZ on April 27, 2013, 01:20:07 PM
Hi Nick
I am aware that something interesting may be going on and have alluded to that by pointing out that the flyback HV secondary presumably cannot  supply the required current when operated with a spark gap into a RF transformer. The current requirement is just too large. Just trying to rule out conventional induction in the RF coil by reverse engineering method.
Look forward to verpies comment on this.
Hoppy
Messy build with long straggly wiring runs may also be a factor here.
T-1000
NickZ
SM had standing wave which he manipulated, I am sure.
In regards to magnetic resonance - as soon as you have resonance with voltage differing from current on 9 0degrees and cut input to LC circuit when current starts to rise and standing wave is made.. you are on the right path :)
Vortex1
You should really study Nicola Tesla power amplification methods with help of spark gap and capacitor discharge... :) And how it affects Tesla coil when discharge is abruptly stopped :)
NickZ
  There does appear to be a number of components that are found in all these different cases. Coils, and caps, are usually present, and a feed back path to most if not all self runners. The load is also very important, but not in the normal way, but in a way that allows this unknown input source to increased the output, to a degree, but with what looks like some limiting factor.
  There is the issue of this unknown input source, which must always come from somewhere, as overunity does not exist, unless you believe in the ¨Big Bang¨.
Maybe it´s due to nuclear decay, or maybe not, but, who can really say that this output is not causing the decay, if radioactivity is actually found, instead of the other way around.
  Wesley is working hard on all of this, with some new information on his rad tests, which is very good for those of us who can´t afford to go that route.
