0 Members and 79 Guests are viewing this topic.
starcruiser
Quote from: itsu on October 24, 2015, 05:01:12 PM
Taking a look at the kacher output with my HV probe (x1000).
I connected it to the open end of the antenna which will load the kacher to some extent presenting a lower frequency and amplitude, but it shows somewhat what we are up against.
Certainly no 26KV or wavefront peak as drawn by akula/ruslan....yet.
Regards Itsu
I think this might be due to the hit and miss I mentioned above. Please take a look and let us know if this is indeed true. IF this is indeed the case this would be why the secondary of the Kacher is not building a higher voltage than the 5kv or so you indicate in your scope shot. THis would indicate that the capacitance at this point should just be enough to provide the adjustment required but not too much. Just my .02
The pulse width IMO should be no less than the time period of the secondaries resonant frequency to get a good output. Less will starve it and too much will mess with its resonance I think.
1.28Mhz = 0.781250 uSec
Regards,
Carl
Tomtech29
Hi.
I have long been a wonder see for yourself
16:26
https://www.youtube.com/watch?v=0CUVsS56xqo
The energy must come with a ferrite core coil 28!
at this point he says that it is necessary that the ferrite rod reverses the magnetic field
that acts as a spring!
3:33
https://www.youtube.com/watch?v=iJniq9SjZiY
Attention
and now see note oscilloscope wave direction
1:31
https://www.youtube.com/watch?v=NVUgZAa1CvM
Good which of you I will explain this to me?
I listen to what he says and I saw as well as the 800 Watt light without the use Kacher!
Pll uses or not after it is strange?
Hoppy
Quote from: Tomtech29 on October 25, 2015, 07:07:09 AM
Attention
1:31
This is rather strange as well: -
John.K1
In one movie Ruslan says how to wind the coil, in other he says don't do it that way, In one movie he says Akula used the ferite rod to fine tune frequency, in different he says it helps to get some spring effect and in his last movies he says there doesn't need to be that ferrite rod at all.
:D
Tomtech29
Quote from: John.K1 on October 25, 2015, 08:24:38 AM
:D
16:45
https://www.youtube.com/watch?v=CpuU2mJxR4k
You understand what he's talking about what's going on with that disperse power?
-and that the output of Tesla is to have the impulse and not to the input
I come back to the old system
https://www.youtube.com/watch?v=Qo4DkJnmCSM
8:00
where the output from the coil grenade is charged capacitor
voltage of 980 Volt enter key (pulse at the gate) a current transformer which is It provides about 6 Ampere 36 volt.- (14V.inverter on)
and further inverter and bulb only to the power of 300 watts.
good is can anyone remember how this transformer is to be wound?
