0 Members and 244 Guests are viewing this topic.
John.K1
Hi Tomtech- I will take a look at it later one. Going away now. Talk you later ;)
itsu
Quote from: verpies on October 24, 2015, 05:34:48 PM
You are correct but I don't see how the PLL could not be synched to voltage if it is transferring energy to the LC circuit (Grenade) from AC voltage sources (switched MOSFETs).
So the question is if they (Akula/Ruslan) are aware that in this case a current transformer will peak on the VOLTAGE and NOT on the CURRENT?
They might THINK that they fire the kacher ontop of the current peak, but instead it is firing ontop of the voltage peak and we should too.
Itsu
itsu
Quote from: starcruiser on October 24, 2015, 05:37:52 PM
I do not think so as the trigger signal is take from the drive signal from the PLL to the Fets for the 15Khz push/pull. SO if the frequency changes the pulse should follow. But you may be correct now that I think about it, but this would always be the issue anyways.
The issue I am concerned with is the fact the more capacitance means it should take a few more cycles to reach trigger point for the logic gates, i.e. t increases. this can be verified by probing the drive signal in the logic gate chain (see capture below) scope the output of the NAND gate against the drive signal, I figure we are seeing a multiple cycles to a signal to the next stage transition signal. like a 4:1 or something like that.
I circled the drive signal sample point after the 3.6k resistor and a blue circle after the second NAND stage.
Starcruiser,
i measured at the points you mentioned, see below screenshot.
Yellow is voltage across the inductor caps
green is the current through the inductor (we are at resonance)
blue is the signal on your red circled point (pin 1 of the 74HC132)
purple is the signal at your blue circled point (pin 6 of the 74HC132)
All referenced to ground.
Itsu
verpies
Quote from: itsu on October 25, 2015, 10:31:38 AM
Maybe they also hacked the subsequent delay of monostables to fire the "Kacher" where they want to.
AlienGrey
Quote from: Tomtech29 on October 25, 2015, 08:36:54 AM
16:45
https://www.youtube.com/watch?v=CpuU2mJxR4k
You understand what he's talking about what's going on with that disperse power?
-and that the output of Tesla is to have the impulse and not to the input
I come back to the old system
https://www.youtube.com/watch?v=Qo4DkJnmCSM
8:00
where the output from the coil grenade is charged capacitor
voltage of 980 Volt enter key (pulse at the gate) a current transformer which is It provides about 6 Ampere 36 volt.- (14V.inverter on)
and further inverter and bulb only to the power of 300 watts.
good is can anyone remember how this transformer is to be wound?
I'm glad you have put a device like this one on here, Some time ago some guy called Sargent Gates made an odd device similar in winds to this but a bit different, any how to cut a story short, i also noticed Akula  Roman used this idea, the thing is it's a real Bugger to get such a device to work, but when it does it does do some magical things, but as i said Tuning is will drive you in sane until you find out whats going on, have fun. Both wingdings have to be in resonance or you get nothing !!!!!!!!!!!!!!!!!!!!!!
