0 Members and 244 Guests are viewing this topic.
AlienGrey
let's go back to basics right, If i have 2 coils both in resonance, for instance an I F  transformer ir both coils are 455kh i will get maximum transfer of energy, the same if i use a mixer and change the frequency to some other frequency, the new I F coil has to be tuned or nothing, it's called exaltation every thing in the universe works on the same principal. However to if you want to sustain that resonant vibration wouldn't it be easier to select a medium that is purported by that vibration, for those i have lost, a self oscillating frequency preferably an angelic self resonating one. Or it don't work ! if you get involved in this type of tuning fork you might notice the length of time it vibrates for and it's capability of exciting a number of forks of the same frequency.
you could just use a tuning fork, and keep bashing it electronically, or a good set of wind chimes ;)
Jeg
Hi Itsu. Is it possible to measure the voltage at grenade's ends while only the inductor line is working? Without the 28T in to play. My output with only the use of inductor is 40V pk-pk. My resonant frequency inside inductor's line is 17KHz. Isn't my output voltage very low? My input while measuring was 24V @ 2A.
Ps. I need a push pull circuit for outputting enough current at 24V with a good snubber. Do you find allega's circuit capable for 6 A without problems? Is its snubber effective?
SolarLab
F.Y.I.
continuation, in part, from my post:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg455673/#msg455673
Source of FE (CE) [possible] <<scientific based experimental and theoretical>>
Where does the excess energy in Ruslan's [et.al.] device originate - whats the mechanism?
Also: Does anyone have Ruslan's latest Oct 6, 2015 (removed) video
"Заряды из воздуха" {"The charges from the air"}?
Recent Thunderstorm investigation, analysis and modelling appear to confirm, to some
extent at least, that C.T.R. Wilson's 1925 discovery of "runaway electron" mechanism
in which fast moving electrons obtain large energies from static electric fields in air.
Furthermore, these fast electrons "avalanche" or exceeding their "break-even" (loss due to
ionization) energy to where there is a large electron energy gain.
Interestingly, much of this early work transpired around the beginning of the last
century (1900) and focused on thunderstorms (coinciding with Tesla's observations and
experiments). Although the entire subject of "fast accelerated electrons and energy gain" can
be somewhat involved, the fundamental concept of using High Voltage potential fields
to rapidly accelerate electrons such that they [magically] gain energy does have an
appeal [and reward].
Of course, other electrical characteristics and techniques are required to ensure
preservation and efficient harvesting of this excess energy but that's typical for
nearly all electrical systems; both closed and open loop.
The following links will assist in finding information, etc, - should there be any interest
(don't get hung up on the "atmospherics research" focus - think FE (CE) generation).
Wilson's original 1925 paper:
http://www.storm-t.iag.usp.br/pub/ACA0330/papers/Wilson_electricfield_thunderstorms_1924.pdf
Runaway Breakdown and the Mysteries of Lightning:
http://nlpc.stanford.edu/nleht/Science/about/gurevich05phystoday.pdf
Dwyer, et. al. "High-Energy Atmospheric Physics: Terrestrial Gamma-Ray Flashes and
Related Phenomena:"
http://people.ee.duke.edu/~cummer/reprints/146_Dwyer12_SpaSciRev_TGFReview.pdf
EXPLANATIONS OF THE RESULTS OF ROGER'S AND BERTOZZI'S EXPERIMENTS WITHOUT RESORT TO
SPECIAL RELATIVITY:
http://musada.net/Papers/Paper8.pdf
Is the same effect (fast electrons) found here?
[[Note: It is argued that in "waveguide modes" the wall-to-wall electron travel can be faster than "C"]]
http://www.researchgate.net/profile/Hitendra_Malik/publication/231847786_Energy_gain_by_an_electron_  in_the_fundamental_mode_of_a_rectangular_waveguide_by_microwave_radiation/links/552feb3d0cf20ea0a06f  5fe5.pdf
fin.
itsu
Quote from: Jeg on October 26, 2015, 01:25:21 PM
Hi Jeg,
sure, with nothing attached to the grenade, so "open eneded" the voltage is 750V pp,  this at 24V / 7.7A input to the inductor, see screenshot 1.
With a 40W/220V bulb attached to the grenade, there is 616V pp with 24V / 6.2A input to the inductor, see screenshot 2
We are at resonance here, so your 40V pp looks very low indeed.
I still have the old snubber system i used on the TL494, so i have no experience with this new setup, only on the Kacher driver circuit, there it works very good.
Regards Itsu
Jeg
Quote from: itsu on October 26, 2015, 03:57:07 PM
Hi Itsu.Thanks a lot. I remeber that before one year i was also lighting a bulb with just the inductor line. Something is wrong with my push pull. Do you remember the values of your snubber?
Also, have you insulated your yoke core halfs between each other, or you attach them directly?
Ps. My pwm goes about up to 50%. What about yours? I use the first akula circuit with 494 and 2110.
Just noticed. You measured your inductor's voltage while i am getting this 40V pk-pk at grenade's ends. I will also measure my inductor's voltage across the tuning cap to see what is happening.
